Shop Built SD (Kind of) http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=68986 |
Author: | rotten_1 [ Sat Nov 19, 2016 6:28 pm ] |
Post subject: | Shop Built SD (Kind of) |
I have known for a while my budget (wife) would not allow a SD to be purchased new so I have decided to build one with the help of a MB lower I picked up a year ago. Here is my progress for now, still trying for figure it out, but I'm coming along. Started with the 27" MB lower I picked up from a user here. After looking for a housing or a 8"x2" rectangle tub with no luck, I decided to weld one up. I'm not a welder so all the seams will need to be ground and smoothed. After a search on McMaster & Carr I found the timingbelt and gears for the MB lower and from Harbor Freight a new predator motor. I just started on the transom mount (again building from scratch, and welds are definitely not pro quailty.) I should be able to start bolting everything together this week to see about fitment and alignment as most all the parts are here. Sent from my SM-G920V using Tapatalk |
Author: | Gunshinestate407 [ Sat Nov 19, 2016 7:08 pm ] |
Post subject: | Re: Shop Built SD (Kind of) |
I have a mounting plate for the power head (small block) off a MudBuddy HD that I can part with. Let me know if u need it |
Author: | Buckmark311 [ Mon Nov 21, 2016 2:24 pm ] |
interested to see how this bad boy turns out. |
Author: | rotten_1 [ Mon Nov 21, 2016 4:37 pm ] |
I got the Motion Base mocked up and aligned. Now I'm waiting on the darn Woodruff Key forthe lower gear. Having issues finding a metric key. Sent from my SM-G920V using Tapatalk |
Author: | Westi [ Tue Nov 22, 2016 5:13 pm ] |
I'm gonna go ahead and follow this. Good luck. |
Author: | rotten_1 [ Wed Nov 23, 2016 9:07 am ] |
I ran into my first major design snag. Maybe I have not noticed it in other engines, but the mounting plate is off center to the shaft of the motor by about 3/4". This doesnt make a large difference in the overall idea I have in my brain, but definatly frusterating it didn't initially work as expected for further progress last night. Sent from my SM-G920V using Tapatalk |
Author: | CypressCritter [ Wed Nov 23, 2016 11:33 am ] |
Is that steel your making the frame out of? That's going be 1 heavy bitch! |
Author: | SETx Longtail [ Fri Nov 25, 2016 4:06 pm ] |
The GoDevil Surface Drive frame, transom mount, and outdrive are 100% plate steel, and no heavier than the competition. This one will be just fine. |
