It is currently Wed Dec 17, 2025 5:22 am
[ 7 posts ] |
Biggerjigger
 27GD SD Dies under load.
I have a stock SG 27hp Kohler Command SD on a F&F 1544 with pods. 2 people and a cooler it turns about 4100RPM at WOT down river 23MPH tops. (Seems slow to me.) Loaded with 3 Big men a cooler and a chainsaw it drops WAY down to like 3000 RPM and will barely break 10 MPH. It is all stock with the GD 11X12 3 blade that im sure is worn a bunch. Will a prop change or a pulley change help me?
| Mon Feb 13, 2017 11:42 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
 Re: 27GD SD Dies under load.
15x44 with pods and a 27 with three big guys......you should at least be doing 30 mph. Maybe you need a K&N air filter to really open it up some......Call Coco and tell him you want the faster pulleys when you get a new prop.
| Mon Feb 13, 2017 12:54 pm |
Biggerjigger
Call who?
| Mon Feb 13, 2017 1:10 pm |
libertarian
Joined: Wed Jan 21, 2015 6:09 pm Posts: 105 Location: SE Texas
Check your water/fuel filter for rust. Especially if it's a Sierra.
_________________ GoDevil 18X44 GoDevil 35 SD
| Tue Feb 14, 2017 2:36 pm |
brycecheramie
| Wed Feb 15, 2017 8:00 am |
Russ
Have to be trolling, but just in case you arent: no. Prop or pulley change isn't going to fix that. It's a small boat with a lot of weight. That's just about the normal performance with that load on a boat that size.
| Wed Feb 15, 2017 8:39 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
Russ summed it up well.
My 25 subaru will run great with a 2 man load. Throw a 3rd person in the mix and it becomes a slug.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Wed Feb 15, 2017 9:06 am |
[ 7 posts ] |
