| What's the verdict on the GTR 3 blade vs 2 blade prop? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=69745 |
| Author: | MNGunner [ Tue Feb 07, 2017 4:54 pm ] |
| Post subject: | What's the verdict on the GTR 3 blade vs 2 blade prop? |
Now that the 3-blade has been out for a few years, what is the verdict vs the 2-blade?? It's been discussed some, but the older threads were all over the map (one went south when AKA started chiming in). Also are there different pitches available--it looked like GTR's website only lists a 10.5? Which is better for: Top Speed? Hole shot? Weeds? Reverse? Mud? Vibration/Tiller torque? I'm interested for a 2013 pure stock GTR35 that is currently running a two blade. Especially interested in comments from guys that have tried both. Thanks |
| Author: | Quack N Stack [ Tue Feb 07, 2017 8:41 pm ] |
| Post subject: | Re: What's the verdict on the GTR 3 blade vs 2 blade prop? |
I ran one for about a year and switched to a 2 blade and liked the 2 more. Went back to a 3 blade for whatever stupid reason and ran it for about 20 minutes and couldn't get that sucker off fast enough. I choose 2 blade any day over the 3....reverse is better, hole shot is better, and load carry is better...also dosent have as much tiller torque. The 3 blade is faster on the top when empty but thats the only place it beats the 2 blade. Vibration is alittle more but thats easy fix with balancing. In grass the three blade only gets about 5 feet in reverse before the prop needs to be cleared, i can back up as far as i want to with a 2 blade. |
| Author: | MNGunner [ Tue Feb 07, 2017 8:57 pm ] |
| Author: | jayrod075 [ Wed Feb 08, 2017 8:50 am ] |
I'm running a 3 blade on a 37GTR efi with a 17x54 extreme. The 3 blade came on it and I can't complain about the speed, but I can complain about the poor reverse performance. I just got a 2 blade in and plan to take it out this weekend. Will report back with some first impressions. |
| Author: | MNGunner [ Wed Feb 08, 2017 7:38 pm ] |
| Author: | mizzippi jb [ Thu Feb 09, 2017 9:47 am ] |
Mines a 2010 motor and frame. I tried a 3 blade and the tiller torque was bad. I don't have any to speak of with a 2 blade. I'll be sticking with a 2 blade with this particular motor Sent from my SM-G900V using Tapatalk |
| Author: | TPerkins [ Thu Feb 09, 2017 10:41 am ] |
2 blade fo lyfe Sent from my SM-G930V using Tapatalk |
| Author: | MNGunner [ Fri Feb 10, 2017 7:11 am ] |
| Author: | fireman1562003 [ Fri Feb 10, 2017 8:54 am ] |
| Author: | fireman1562003 [ Fri Feb 10, 2017 8:57 am ] |
im running the stock 3 blade on a 2016 37EFI GT and reverse sucks and whole shot sucks . been told to go to Big Blade so waiting on it to get here ! |
| Author: | Quack N Stack [ Fri Feb 10, 2017 11:05 am ] |
| Author: | Quack N Stack [ Fri Feb 10, 2017 11:08 am ] |
| Author: | ibfishinb [ Mon Feb 13, 2017 6:29 am ] |
2011 gtr 2 blade power tech (worked) Pros: Fast at all ranges Awesome holeshot Great in reverse Great in grass Cons: LOTS of tiller torque 3 blade (worked) Pros: Hardly any tiller torque Very little vibration Makes driving more enjoyable on a long run Cons: Holeshot not as good as 2 blade Reverse not as good as 2 blade Speeds not as good as 2 blade Reverse is poor Sent from my SM-G920V using Tapatalk |
| Author: | Zeek569 [ Mon Feb 13, 2017 9:23 am ] |
merc 3 blade on my gtr the good its very smooth and zero tiller torque reverse is stronger than a 2 blade as long as your not in thick grass or mud 2 mph faster than my worked big blade loaded or unloaded the cons its a little slower to get on step with a load it get clogged up with grass only time a two blade is on my boat is when i know things are about to get bad. |
| Author: | jayrod075 [ Mon Feb 13, 2017 2:32 pm ] |
Well I took the new 2 blade out this weekend for bowfishing. WOW- I really like it. I noticed considerably less tiller torque when my load was off balance. I find the three blade is much more picky about having a perfectly balanced load. As for performance with the 2 blade: I may have lost 1mph on the GPS vs the 3 blade. Getting on plane in shallow water was easier and WHAT A DIFFERENCE the 2 blade makes in reverse. I can maneuver all over in reverse now. I'll continue to run the 2 blade for all things shallow. If I'm out going fishing and going to be in fairly deep water I may break the 3 blade back out. |
| Author: | MNGunner [ Tue Feb 14, 2017 7:34 am ] |
Thanks for the replies--interesting some people find the exact opposite of others. |
| Author: | Russ [ Tue Feb 14, 2017 8:20 am ] |
| Author: | Zeek569 [ Tue Feb 14, 2017 11:20 am ] |
it all depends on what 3 blade you run. the merc 3 blade will out perform the 2 blade in reverse and speed but the two blade will have better hole shot and much better in grass the power tech 3 blades will be smother and run better with light loads but will struggle in reverse and mud/veggies. this goes for most boats. some boats hate 3 blades |
| Author: | jayrod075 [ Tue Feb 14, 2017 11:29 am ] |
