| G4 Prodrive auto reverse issue http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=71333 |
| Author: | woodie_slayer [ Fri Sep 29, 2017 8:32 am ] |
| Post subject: | G4 Prodrive auto reverse issue |
Has anyone ever had their prodrive trim down a lot while shifting to reverse? I was told it might be the solenoid or the pump. |
| Author: | cb5331 [ Fri Sep 29, 2017 10:03 am ] |
| Post subject: | Re: G4 Prodrive auto reverse issue |
Newer ones just use a single pump, right? If yes, then I would say there is an issue with the solenoid. |
| Author: | woodie_slayer [ Fri Sep 29, 2017 10:16 am ] |
Yes,its just one pump.If it is the solenoid,how would know if its going out? Thanks |
| Author: | cb5331 [ Fri Sep 29, 2017 10:42 am ] |
If you hit the switch to put the LU in reverse and it moves the trim, I would say the solenoid has already gone out. Give pd a call, they may be able to give you some other things to check first, but I think the solenoid is bad. |
| Author: | woodie_slayer [ Fri Sep 29, 2017 10:47 am ] |
Thanks man ill check it out. |
