| Aftermarket prop for prodrive http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=71711 |
| Author: | CodyR [ Mon Dec 11, 2017 3:46 pm ] |
| Post subject: | Aftermarket prop for prodrive |
I have 25hp prodrive. I'm curious to know if changing prop will help with heavier loads and getting on top of water faster. Problem is I can't seem to find anyone who makes an aftermarket prop for this motor. Any help is appreciated. |
| Author: | brycecheramie [ Mon Dec 11, 2017 3:50 pm ] |
| Post subject: | Re: Aftermarket prop for prodrive |
| Author: | CodyR [ Mon Dec 11, 2017 4:00 pm ] |
10-4 thanks. |
| Author: | brycecheramie [ Mon Dec 11, 2017 4:06 pm ] |
| Author: | CodyR [ Mon Dec 11, 2017 4:13 pm ] |
I hear ya. I was just curious because ive been reading on all these different props that say they improve hole shots and other areas as well. I wasn't able to find anything specifically designed for my motor and I'm a rookie when it comes to mechanics so I was unsure of what to do. thanks for your info. |
| Author: | BlueShamu [ Mon Dec 11, 2017 4:19 pm ] |
Is your shaft threaded or splined? Sent from my iPhone using Tapatalk |
| Author: | CodyR [ Mon Dec 11, 2017 4:22 pm ] |
Threaded |
| Author: | BlueShamu [ Mon Dec 11, 2017 8:55 pm ] |
You have a lot of options. Standard 2 or 3 blade from PD, Hopkins Cleaver and I think LA Prop has another style similar to the Big Blade....don't quote me on the last one....check with him. |
| Author: | CypressCritter [ Tue Dec 12, 2017 8:23 am ] |
Or better yet have your prop shaft replaced with one with a hex on it like Gatortail and MudBuddy, then your prop options are expanded. |
| Author: | BlueShamu [ Tue Dec 12, 2017 11:02 am ] |
| Author: | CodyR [ Tue Dec 12, 2017 11:38 am ] |
ok ill look into all that. thanks for the help. I also saw where backwater performance makes a prop for a 3/4" threaded shaft but not sure how it would work with gear ratio of pd. |
| Author: | wade_660 [ Tue Dec 12, 2017 12:02 pm ] |
| Author: | brycecheramie [ Tue Dec 12, 2017 1:16 pm ] |
| Author: | CodyR [ Tue Dec 12, 2017 2:04 pm ] |
unfortunately I'm not in the financial position to just unload my current motor and replace it with a bigger one. I understand a big block is a lot stronger that's just not an option for me right now. |
| Author: | Fuquabw2016 [ Tue Dec 12, 2017 6:03 pm ] |
Three blade helps my 25 Prodrive when got a load |
| Author: | CodyR [ Tue Dec 12, 2017 6:37 pm ] |
Which 3 blade? |
| Author: | CypressCritter [ Wed Dec 13, 2017 8:36 am ] |
| Author: | wade_660 [ Wed Dec 13, 2017 8:48 am ] |
Chris at LA Prop put me in touch with the guy. I’ll have to look for his number. Basically I sent him my shaft, he built one and put my gears, bearings, and such on. Jam up guy. Sent from my iPhone using Tapatalk |
| Author: | Glade [ Wed Dec 13, 2017 11:13 am ] |
Can someone tell me exactly which shaft styles ProDrive has used through the different generations? |
| Author: | brycecheramie [ Wed Dec 13, 2017 11:35 am ] |
| Author: | wade_660 [ Wed Dec 13, 2017 12:08 pm ] |
Only thing with doing this is that you need to have a built prop since Prodrive has a lower gear ratio that other manufacturers. I had a stage 2 motor and could bury a worked 3 blade and bounce off the limiter. The big blade that was on it when I sold it was built with a ton of cup. It wasn’t perfect but was manageable. I would think a gen 3 would be tricky to find a prop to work. Sent from my iPhone using Tapatalk |
| Author: | 50fps [ Wed Dec 13, 2017 12:12 pm ] |
| Author: | wade_660 [ Wed Dec 13, 2017 12:30 pm ] |
Without a doubt. Sent from my iPhone using Tapatalk |
| Author: | CodyR [ Wed Dec 13, 2017 1:24 pm ] |
if my pd shaft was splined instead what options would I have for props then? not familiar with what pitch or size props this motor can handle |
| Author: | Glade [ Wed Dec 13, 2017 3:33 pm ] |
| Author: | wade_660 [ Wed Dec 13, 2017 4:57 pm ] |
You might could spin a stock Big blade. Hard to say since mine was a stage 2 big block. Sent from my iPhone using Tapatalk |
| Author: | CodyR [ Wed Dec 13, 2017 5:15 pm ] |
i have bps q exhaust with fuel tuner but that’s as far as I’ve gone with mods so far |
| Author: | trhkr2 [ Wed Dec 13, 2017 6:32 pm ] |
My brother just had his Gen2 threaded driveshaft swapped to a hex... Nick Peltier fixed us up... |
| Author: | CodyR [ Wed Dec 13, 2017 6:51 pm ] |
| Author: | Russ [ Wed Dec 13, 2017 7:15 pm ] |
Laprop, Chris 3372772852 #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | CodyR [ Wed Dec 13, 2017 8:00 pm ] |
Thank you |
| Author: | Duckhunter18 [ Thu Dec 14, 2017 4:00 am ] |
| Author: | CodyR [ Thu Dec 14, 2017 5:35 am ] |
| Author: | 50fps [ Thu Dec 14, 2017 8:37 am ] |
| Author: | wade_660 [ Thu Dec 14, 2017 10:46 am ] |
| Author: | Fuquabw2016 [ Thu Dec 21, 2017 11:05 am ] |
