It is currently Wed Sep 09, 2026 11:27 pm
Reply to topic  [ 36 posts ]
 Aftermarket prop for prodrive
Post Aftermarket prop for prodrive
I have 25hp prodrive. I'm curious to know if changing prop will help with heavier loads and getting on top of water faster. Problem is I can't seem to find anyone who makes an aftermarket prop for this motor. Any help is appreciated.
Mon Dec 11, 2017 3:46 pm
Post Re: Aftermarket prop for prodrive
Mon Dec 11, 2017 3:50 pm
10-4 thanks.
Mon Dec 11, 2017 4:00 pm
Mon Dec 11, 2017 4:06 pm
I hear ya. I was just curious because ive been reading on all these different props that say they improve hole shots and other areas as well. I wasn't able to find anything specifically designed for my motor and I'm a rookie when it comes to mechanics so I was unsure of what to do. thanks for your info.
Mon Dec 11, 2017 4:13 pm
Is your shaft threaded or splined?
Mon Dec 11, 2017 4:19 pm
Threaded
Mon Dec 11, 2017 4:22 pm
You have a lot of options. Standard 2 or 3 blade from PD, Hopkins Cleaver and I think LA Prop has another style similar to the Big Blade....don't quote me on the last one....check with him.
Mon Dec 11, 2017 8:55 pm
Or better yet have your prop shaft replaced with one with a hex on it like Gatortail and MudBuddy, then your prop options are expanded.
Tue Dec 12, 2017 8:23 am
Tue Dec 12, 2017 11:02 am
ok ill look into all that. thanks for the help. I also saw where backwater performance makes a prop for a 3/4" threaded shaft but not sure how it would work with gear ratio of pd.
Tue Dec 12, 2017 11:38 am
Tue Dec 12, 2017 12:02 pm
Tue Dec 12, 2017 1:16 pm
unfortunately I'm not in the financial position to just unload my current motor and replace it with a bigger one. I understand a big block is a lot stronger that's just not an option for me right now.
Tue Dec 12, 2017 2:04 pm
Three blade helps my 25 Prodrive when got a load
Tue Dec 12, 2017 6:03 pm
Which 3 blade?
Tue Dec 12, 2017 6:37 pm
Wed Dec 13, 2017 8:36 am
Chris at LA Prop put me in touch with the guy. I’ll have to look for his number. Basically I sent him my shaft, he built one and put my gears, bearings, and such on. Jam up guy.
Wed Dec 13, 2017 8:48 am
Can someone tell me exactly which shaft styles ProDrive has used through the different generations?
Wed Dec 13, 2017 11:13 am
Wed Dec 13, 2017 11:35 am
Only thing with doing this is that you need to have a built prop since Prodrive has a lower gear ratio that other manufacturers. I had a stage 2 motor and could bury a worked 3 blade and bounce off the limiter. The big blade that was on it when I sold it was built with a ton of cup. It wasn’t perfect but was manageable. I would think a gen 3 would be tricky to find a prop to work.
Wed Dec 13, 2017 12:08 pm
Wed Dec 13, 2017 12:12 pm
Without a doubt.
Wed Dec 13, 2017 12:30 pm
if my pd shaft was splined instead what options would I have for props then? not familiar with what pitch or size props this motor can handle
Wed Dec 13, 2017 1:24 pm
Wed Dec 13, 2017 3:33 pm
You might could spin a stock Big blade. Hard to say since mine was a stage 2 big block.
Wed Dec 13, 2017 4:57 pm
i have bps q exhaust with fuel tuner but that’s as far as I’ve gone with mods so far
Wed Dec 13, 2017 5:15 pm
My brother just had his Gen2 threaded driveshaft swapped to a hex... Nick Peltier fixed us up...
trhkr2
Wed Dec 13, 2017 6:32 pm
Wed Dec 13, 2017 6:51 pm
Laprop, Chris
3372772852
#TheGhostBoat
Wed Dec 13, 2017 7:15 pm
Thank you
Wed Dec 13, 2017 8:00 pm
Thu Dec 14, 2017 4:00 am
Thu Dec 14, 2017 5:35 am
Thu Dec 14, 2017 8:37 am
Thu Dec 14, 2017 10:46 am
Thu Dec 21, 2017 11:05 am
