| Gear teeth on my 2012 gtr http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=71863 |
| Author: | on da bayou [ Mon Jan 08, 2018 5:41 pm ] |
| Post subject: | Gear teeth on my 2012 gtr |
I have a 2012 35 gtr With hydraulic reverse wanting to know how many teeth or on the top pulley and how many teeth is on lower pulley on a stock gtr also what is the prop size and Pitch it is in a two blade and a three blade if any one know Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Mon Jan 08, 2018 6:05 pm ] |
| Post subject: | Re: Gear teeth on my 2012 gtr |
Take the transmission cover off. It'll have a 48 stamped on either the right or left side if it is 48 Sent from my iPhone using Tapatalk Pro |
| Author: | on da bayou [ Mon Jan 08, 2018 8:24 pm ] |
| Author: | bluesky2012 [ Mon Jan 08, 2018 8:27 pm ] |
The bottom is 48. The top is what ever you count to. I don't think the top has ever changed. I think the ones changed around 2012 went from 42 to 48 but I may be backwards. Sent from my iPhone using Tapatalk Pro |
| Author: | Russ [ Mon Jan 08, 2018 8:36 pm ] |
The bottom used to be 45, changed to 48 around that time. The top is 36, I think. Marcus will be along shortly to correct me if it's 38. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | on da bayou [ Mon Jan 08, 2018 8:37 pm ] |
| Author: | Russ [ Mon Jan 08, 2018 8:39 pm ] |
12x10 #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | on da bayou [ Mon Jan 08, 2018 8:40 pm ] |
| Author: | bluesky2012 [ Mon Jan 08, 2018 8:43 pm ] |
If Russ says it is, then it is. Thanks for the correction on 45 and not 42. Drinking beers and watching Alabama hopefully lose doesn't make for a strong memory of obscure facts. Sent from my iPhone using Tapatalk Pro |
| Author: | on da bayou [ Mon Jan 08, 2018 8:48 pm ] |
If u always have to push away with the tiller handle from u which way should I bend the tabs thanks Sent from my iPhone using Tapatalk |
| Author: | bluesky2012 [ Mon Jan 08, 2018 8:51 pm ] |
Away from you. Check your weight distribution first and also prop plays into effect. Since you have a worn prop, may want to wait till you have a new one and see how that plays in. Sent from my iPhone using Tapatalk Pro |
| Author: | Russ [ Mon Jan 08, 2018 8:55 pm ] |
Trim level affects the felt torque a lot, and a fresh prop will change where it's trimmed for best thrust. Unless you're gonna use that prop a while, just wait on the bending stuff. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | on da bayou [ Mon Jan 08, 2018 9:09 pm ] |
Thanks baggy’s got my prop now to get work Sent from my iPhone using Tapatalk |
| Author: | MaXXis85 [ Tue Jan 09, 2018 6:18 am ] |
Top gear is 38 Current bottom is 48. Used to be 45 lower, but was changed around 2011-2012 ish. The CDI motors additional charging system put more load on these units aswell as larger boats, 3 blade propellers were coming out; so they needed a lower gear ratio. 38/45 = 1.18:1 38/48 = 1.26:1 |
| Author: | CypressCritter [ Tue Jan 09, 2018 10:39 am ] |
I have a 2011 GTR CDI its a 38/45 and came stock with a power tech 12x10 |
| Author: | pokey79 [ Tue Jan 09, 2018 1:51 pm ] |
| Author: | on da bayou [ Thu Jan 11, 2018 7:41 pm ] |
| Author: | MaXXis85 [ Fri Jan 12, 2018 7:36 am ] |
Port side top of belt box. |
