| Washer? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=72291 |
| Author: | boatguy [ Wed Apr 04, 2018 4:53 am ] |
| Post subject: | Washer? |
Took my prop off to clean shaft and threads... Does the washer go on before for the prop or after the prop. 4400 HDR Mud Buddy |
| Author: | Koondog62 [ Wed Apr 04, 2018 7:08 am ] |
| Post subject: | Re: Washer? |
On my gatortail it is after and it is shaped to hold pressure on nut and prop. Can not remember the name of the washer. |
| Author: | Russ [ Wed Apr 04, 2018 7:47 am ] |
So it's a "pressure washer"? #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | Koondog62 [ Wed Apr 04, 2018 8:50 am ] |
| Author: | Russ [ Wed Apr 04, 2018 10:17 am ] |
I wasn't being helpful, just said it outloud, chuckled, figured I let others have a potential chuckle over a stupid pun. Back on topic. The washer needed there isn't a big deal, as long as it's the right thickness. The op has the washer, just wanted to confirm location for install. You done solved that riddle for him. #CFFITR #TheGhostBoat #whoneedsphysicsihaveamudmotor |
| Author: | BlueShamu [ Wed Apr 04, 2018 10:38 am ] |
I'm not familiar with the washer at all...but, if it's like you describe, that's called a belleville washer. It's cupped to give additional compressional forces to keep a nut in place and keep tension on the mechanical joint. If it is truly a Belleville washer, they typically are placed under the nut. They are dish/cone shaped. The smaller surface should be against the nut. |
| Author: | Koondog62 [ Wed Apr 04, 2018 10:56 am ] |
| Author: | Koondog62 [ Wed Apr 04, 2018 10:59 am ] |
| Author: | boatguy [ Thu Apr 05, 2018 5:08 pm ] |
Ok,, so I took the BB off to put the new Hammer blade on... this washer will not fit inside the Hammer blade. I put the Hammer blade on the shaft then go to put the washer on and the washer is slightly bigger than the recessed area of the prop... Is this common... I wound up sanding the diameter of the washer down a bit so it would fit in the recessed hole of the Hammer prop... ??? |
| Author: | Old School [ Fri Apr 06, 2018 6:56 pm ] |
Boat guy is a cool handle Sent from my iPhone using Tapatalk |
