| pd clutch switch http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=7234 |
| Author: | jer1945 [ Tue Jan 19, 2010 12:52 pm ] |
| Post subject: | pd clutch switch |
smoked 2 switches, the clutch is drawing more then 10 amps. it still runs, but the switch doesn't last more then a sec. if i bypass it it does fine. |
| Author: | stumpgrinder [ Tue Jan 19, 2010 1:37 pm ] |
| Post subject: | Re: pd clutch switch |
think I remember someone posting that the clutch draws near 20 amps... anyone know for sure? don't know why ur fryin da switches though... |
| Author: | jer1945 [ Tue Jan 19, 2010 5:54 pm ] |
the 10 amps it pulls is heating up the wires, i'll have to replace the clutch. is there a parts brakedown out there somewhere? jer |
| Author: | cb5331 [ Tue Jan 19, 2010 7:24 pm ] |
you talkin bout the pto switch? The red one? If your burnin em up like that, you have a short somewhere. Check all your wiring for a pinch or cut. Thats not normal. |
| Author: | stumpgrinder [ Wed Jan 20, 2010 6:50 am ] |
u prolly either got a short in ur wiring somewhere or in the armatuer of ur clutch. u said if you bypass da switch da clutch works... is that when ur wiring is gettin hot? If so, that's not classified as working. lol That circuit ain't real complicated and should be easy to troubleshoot, but we need a lil more info. Worst case scenario you have to replace ur clutch, which takes less than an hr. with the proper tools and a hoist to lift the top side. 4 bolts to remove da top side, then 4 more bolts to remove da spline adapter from da clutch, then 1 more bolt holds the clutch on. When you remove ur clutch the last thing that comes off is a bushing/spacer..... pay close attention to which way that thing is oriented and re-install the same way. If for some reason u get it confused.... the beveled end goes towards da engine. |
| Author: | muddiejeep [ Wed Jan 20, 2010 8:27 am ] |
check under the engine where the wires go into the clutch assembly. thats where mine got cut and fried the wiring harness and the magnetic clutch. |
| Author: | jer1945 [ Wed Jan 20, 2010 1:54 pm ] |
checked the wires, they all look good. it's a new clutch, i guess. |
| Author: | jer1945 [ Thu Jan 21, 2010 10:39 am ] |
found the trouble, the bearing was all but gone, just a few ball bearing left. |
