It is currently Mon Apr 06, 2026 6:39 pm
[ 3 posts ] |
2ND Hand Performance upgrades....
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
1848 Geaux Customs Bare Bones Edition 09 36 PD FPR, HydroTrim 2 Batteries 6gal fuel 1guy-250lbs
Mod's Stage II EVT heads -EVT Roller Rockers (lash .005), Port/Polish, Decking 50-55 not positive (no markings on casting found), stock gasket set, Stock Valve springs Shimmed at .100 -BPS Exhaust salvaged from Mitch (Thanks)- gutted and rewelded LOOOOOOOUUUUUUUDDD! Needs baffle -Ported and polished intake using DB8 directions............Thanks -MB 45mag Gov. Spring
-prop has seen better days but not too bad............
Before- these are all good weather conditions (no wind, little chop) 27-28 deep water 28-29 shallow water- dam close to 30 though all at 4100rpm best speed, gov.spring set at 4350rpm maxed out
After Mod's- 20plus mph winds heavy chop deep water (white caps)- head wind at that constant -27mph running at 4300rpm Gov.spring was set at 4400
Overall very happy, speeds were down I'm sure because of weather but throttle response is much improved, boat gets on step faster and motor does not lay down at all when you hammer it out of the hole....................So far so Good... Knock on Wood.....
Special Thanks, to Mudd, DB8 and Mitch for the info and hook up!
_________________ If I can't Break it, it can't be Broke.............................
| Tue Apr 19, 2011 12:48 am |
XGEN-DUCKMAN
 Re: 2ND Hand Performance upgrades....
Hope I'm not the only one: But I hate setting the Gov.Spring, these dam things sound like they are gonna blow bouncing off the Govenor!
| Tue Apr 19, 2011 1:02 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
Xgen-duckmen: please enter your boat and motor data below. Thanks
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
| Tue Apr 19, 2011 6:42 am |
[ 3 posts ] |
