Trailering your Copperhead SD...
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=21463
Author:  DUCK-DAWG [ Sat Aug 27, 2011 3:43 pm ]
Post subject:  Trailering your Copperhead SD...
My trailer is too low to the ground to trailer my Copperhead as the instructions describe, has anyone else come up with another way to trailer theirs?
Author:  russellm454 [ Sat Aug 27, 2011 5:35 pm ]
Post subject:  Re: Trailering your Copperhead SD...
Curious, how do they say to trailer a Copperhead?
Maybe you could run taller tires also.
Author:  s.c.i.e.n.c.e [ Sun Aug 28, 2011 7:04 pm ]
Author:  dog walker [ Sun Aug 28, 2011 7:26 pm ]
that's weird
Author:  russellm454 [ Sun Aug 28, 2011 8:00 pm ]
Sounds like they are trying to take as much weight off of the trim unit as possible. What you pulling it with. Any lowering of the trailer tongue will raise the prop while trailering. You might be able to go with a dropped hitch.
Author:  cmiller73 [ Mon Aug 29, 2011 8:02 am ]
You could possibly make a "transom saver" for it. And have it set where it wouldn't be too low.
I usually take mine and turn the handle to the left, put a cinch strap on it while tilted down. Tighten up the strap, then tilt it up on the manual tilt, tightening up the strap more. This way it doesn't bounce up and down or twisted side to side.
Author:  scott0227 [ Mon Aug 29, 2011 7:31 pm ]
I have been strapin mine down by the handle and I have a home made transoome saver with rubber on it. I will take a pic when i get a second. i dont like it turned, rather have prop straight stickin up in the air. I used to turn it but not no mo.
Author:  cmiller73 [ Tue Aug 30, 2011 7:02 am ]
Problem with the Copperhead, is there is no locking mechanism to hold it down. It has to be starpped somehow. I mentioned to Gil about doing something like GT has on theirs. Would be fairly easy to do yourself.
Drill a hole through the sides of the transom mounting plate. Get a bolt with a long smooth shank. Aluminum flat bar and bend it around the belt housing. Trim out end to hook bolt and done.
Author:  spearfish1976 [ Wed Aug 31, 2011 11:51 am ]
cmiller73,
Good idea, i think I'm gonna try that.
DUCK-DAWG,
What about raising the bunk brackets on your trailer. That would raise the whole boat?
Author:  DUCK-DAWG [ Thu Sep 01, 2011 2:13 pm ]
cmiller, I may look into doing that (or something similar) on mine. Up until now, I've been strapping the handle of my motor to the side of my seat while trailering. The only problem I've had with this is that the nuts/bolts attaching the handle to the motor frame tend to loosen on longer drives. What I may do is replace the existing bolts with longer ones, and add 1-2 additional locking nuts to help prevent them from loosening.
Author:  cmiller73 [ Thu Sep 01, 2011 2:18 pm ]
Author:  BASSMASTER [ Thu Sep 01, 2011 2:28 pm ]
^x2 you might need a greater hitch drop
Author:  JIMMY W [ Thu Sep 01, 2011 5:02 pm ]
Author:  UNCLE-J [ Thu Sep 01, 2011 5:52 pm ]
Can't you just unbolt it and put it in te boat? It only weights 25#'s.
Author:  Sko [ Thu Sep 01, 2011 5:57 pm ]
Author:  Woodiebuster [ Thu Sep 01, 2011 7:21 pm ]
Author:  cmiller73 [ Fri Sep 02, 2011 8:02 am ]
Author:  DUCK-DAWG [ Fri Sep 02, 2011 9:36 pm ]
My motor is through-bolted to the transom.
Author:  diceman [ Sat Sep 24, 2011 2:55 pm ]
if you look just forward of the prop, there is a few CNC cut outs above the shaft if you have 2 handles on the back of your boat, i've found the best way to strap is with 2 rachette each one going to each handle on back of boat, trim the unit down a bit, then adjust strap evenley, and your unit will not bounce, turn etc, no need to strap handle, works great ;)
