It is currently Wed Apr 08, 2026 1:05 am
Reply to topic  [ 21 posts ]
 Really big rig
Post Really big rig
I realize most the people on this forum don't have the same requirements as I. On the off chance this info could help someone I thought "why not"?
I just picked up an old 24' X 60" Monarch with a decent bottom. The largest I've run, previously, was a 24' X 48" Alweld with a 35 SD. After taking care of some cosmetic repairs on the Monarch I mounted a High Transom SD on it and took it to the river. I loaded it down with about 1000 lbs not including the engine and battery. This is close to the load I have on a 5 day fishing trip on the Yukon. Upstream speeds in the current was 18mph. If I ran in the eddies next to shore it climbed to 20mph. Downstream speeds were consistently 23-24mph My best speeds came with the tach reading 3550-3570rpm. The engine is a box stock Briggs. Steering was very easy with no push or pull if the load was heavy on one side. Shifting considerable weight forward only decreased speed by 1 or 2 mph. If I kept the load balanced fore and aft the boat only drafted about 4 inches. I was impressed! I really didn't expect it to perform that well.
Mon Jun 18, 2012 12:48 am
Post Re: Really big rig
Thats pretty good for a stock motor.Good info
Mon Jun 18, 2012 7:00 am
Stu, can you try running a prop with less pitch to get the RPM's up some? IIRC the 3500 RPM rpm range isnt the best to run the engine at a heavy load. 3700-3800 would be ideal and have more mechanical advantage.
Mon Jun 18, 2012 8:22 am
Post Really big rig
That's a good idea there white Marcus.
Mon Jun 18, 2012 8:27 am
Post Really big rig
Yep Briggs don't like being loaded down and run 3500-3600 rpm's . They create a bad vibration and shit will happen lol!! When I bow fished out my small boat I ran a prop that would turn 4000 with my normal load!!
17x48 extreme stage 2 GTR
Mon Jun 18, 2012 9:14 am
Mon Jun 18, 2012 9:15 am
Critical speed,for those that don't know google is your friend
Hats off to you once again Mr Stu
Mon Jun 18, 2012 10:37 am
Mon Jun 18, 2012 4:48 pm
Tue Jun 19, 2012 6:19 am
without photo's it's all talk.........Duckdon
Tue Jun 19, 2012 9:30 am
Tue Jun 19, 2012 8:17 pm
Sweet. I would be curious to know if it does better. Theoretically speaking when pushing that much of a load you want some mechanical advantage to help you out and get strain off the motor! Sounds like you got a plan!
Wed Jun 20, 2012 6:26 am
Now that's a Yukon runner........ I'm in on the pike fishing just don't know when I can fit it in. Duckdon
Thu Jun 21, 2012 8:11 am
Just came to me..........That's a late "70's" vintage riveted boat with maybe a .83 thick hull and it's still getting the job done. Nice........Duckdon
Thu Jun 21, 2012 8:14 am
That's Awesome!
You could bring 6 people hunting along with their personal pirouges and still have room.
Thu Jun 21, 2012 8:23 am
Thu Jun 21, 2012 10:56 am
Let us know how the new gears do stu I'm curious to see if it gets your rpms where they need to be
Thu Jun 21, 2012 11:04 am
Thu Jun 21, 2012 2:40 pm
Stu Congrats on 50 years of marriage!
Thu Jun 21, 2012 3:01 pm
Damn good job!!! 50 years and fishing and hunting Alaska today! The good life.
Thu Jun 21, 2012 3:15 pm
Stu, Congrats on the 50th!
I'm curious about those RPM's too. Got your bud to weld my tunnel off...still not gettin it.
John
Sun Jun 24, 2012 12:22 am
