It is currently Mon Apr 13, 2026 4:15 am
[ 4 posts ] |
Honda engine remote throttle
michfish
New member, first post.
Building a CLP longtail kit using a Honda GX200 engine. Specifically - GX200 UT2 QX2.
Pulled the air filter and found that there is no remote throttle cable anchor bolt assembly. I must have made an error when I ordered the QX2 variant from Northern Tool (part number 6067 although it said it was good for a go-kart...)
Now I can't figure out how to order just this part.
Here is the Honda parts page for this engine. You can see parts 25, 18 and 24 - those are the ones I need, I think.
So here are my questions: 1.) Has anyone else stepped into this problem? How did you resolve? 2.) If I need to order the parts, where is the best place to order?
Frustrating moment, to say the least.
Going to mount this on the back of a refurbished Sportspal S-15 square back canoe for fun in the shallows.
Thanks for the help.
| Sun Sep 07, 2014 9:02 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: Honda engine remote throttle
After going through the hassle of finding an air filter to fit on a 22hp honda, I feel your pain... For this I referred to the GX200 owners manual to see they use a simple cable stop thats held on by a snap ring (circlip is what honda refers to)... So you have two options... 1- Take in your owners manual to a napa autoparts (or whatever you like) and point to the picture (It was on pg 16 of mine) and tell them you want that... 2- Get a normal adjustable cable stop and rig it to work... https://www.google.com/search?num=100&c ... wKL-TjkhVc
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Sun Sep 07, 2014 11:05 am |
SwampDonkey1
So it eats at me when I cant actually help someone and within 2 minutes of my last post I found EXACTLY what you want... Its called a universal throttle lever swivel assembly.... Heres one source... http://www.partsreloaded.com/Snowmobile ... -Universal
| Sun Sep 07, 2014 11:11 am |
michfish
Thanks, SD1!
I've got one on order now. Should be on the water next weekend rather than this weekend as planned...
I might try to cobble one together - I'll check some local small engine shops if I get a chance.
Appreciate the research. I had no idea.
| Sun Sep 07, 2014 6:56 pm |
[ 4 posts ] |
