It is currently Tue Apr 07, 2026 10:25 pm
[ 5 posts ] |
leonides
 Brake Lever
Where can I find a Bike or Motorcycle brake lever able to be fitted to a Long Tail Handlebar of 1 1/8".? Must regular bikes take 7/8" Any help will be appreciated . thanks P.B.
| Fri Apr 17, 2015 10:10 am |
Ptuck66
 Re: Brake Lever
Ebay, I bought a HD clutch lever for my 1" Handle, I am sure you can find something for 1 1/8"
| Fri Apr 17, 2015 12:55 pm |
Schmidty721
 Re: Brake Lever
The largest bar diameter you will find on a motorcycle is 1".
If you can find a lever that has a nylon bushing between the mount and bar, you'll be close it 1-1/8" with the bushing removed
| Fri Apr 17, 2015 1:10 pm |
fireman1293
 Re: Brake Lever
Is the ID of your handle 7/8"? If so, shove a piece of 1/2" pipe inside it. It will generally wedge inside because of the seam on the inside of your handle, then put the lever and grip on the 1/2" pipe because the OD is 7/8"
Good luck
| Sun Apr 19, 2015 11:38 am |
leonides
 Re: Brake Lever
Found one that will fit at Ebay, thanks you all for your help. P,B,
| Sun Apr 19, 2015 7:51 pm |
[ 5 posts ] |
