It is currently Fri Apr 03, 2026 8:38 am
[ 9 posts ] |
nickh
 keyway
I just got a used mud buddy 24hp long tail. Below the u joint is a key way and I'm missing the key. I don't see it on the mud buddy parts site. Is it something I need to call for?
| Tue Aug 25, 2015 4:00 pm |
JD145
Joined: Wed Jun 04, 2014 9:01 pm Posts: 1289 Location: SWGA
 Re: keyway
Would a piece of .keystock from the hardware store not suffice?
_________________ 1854 Prodigy DPE Level 3 HDR
| Tue Aug 25, 2015 4:06 pm |
Russ
 Re: keyway
It should. I don't remember the size. You'll have to measure it, but probably 1/4"
| Tue Aug 25, 2015 4:31 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: keyway
You can get a key from a hardware store and cut off what you need. No need in ordering that!
Sent from my beeper
| Tue Aug 25, 2015 7:58 pm |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
 Re: keyway
Some 3/4 yokes have .25 keyways, some have .188 keyways. The motor will most def be 1/4 inch keyway but the prop side can be either one. Measure with a caliper or micrometer. Can get key stock for either size at a hardware store or auto parts store. Easy to find. If you need the .188 size, in fraction form it's 3/16
Sent from...wait, Where am I?
| Tue Aug 25, 2015 8:03 pm |
North LA Hunter
 Re: keyway
| Tue Aug 25, 2015 8:05 pm |
45th parallel
 Re: keyway
For .79 cents I'd buy 2 1/4" keys at the hardware store and keep a spare in the boat.
_________________ 35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close 10hp Swomp lite 14-36 alumacraft
| Wed Aug 26, 2015 3:05 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: keyway
This past season near the end the key slipped out. I bought an oversize one and it held for a couple of hunts till I got it properly fixed plus some beefier set screws; good thing the shaft was good and also the bearing but I had to replace the seals. No chit, on my first LT, an 18 GD, many moons ago, I was upriver and the key slipped out so I jammed some sardine can keys in there and it held enough to get putt back the ten miles to the landing.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Wed Aug 26, 2015 5:57 pm |
nickh
 Re: keyway
Thanks for the info. Got it at the hardware store.
| Fri Aug 28, 2015 10:34 am |
[ 9 posts ] |
