It is currently Tue Apr 07, 2026 9:13 pm
Reply to topic  [ 11 posts ]
 upper bushing temps
Post upper bushing temps
Hey fello long tailers, qustion for ya how hot are thease go devil upper bushing soposta run at normally? Everthing works as it should I recently swapped out the old style packing gland seal for the double seal unit from go devil to seal up the drive shaft. Other than that it qorks great just wonder how hot that upper is soposta run. Thanks guys!
14x44 riveted flat bottom jon pushed by old skool hopped up 15Hp GDLT.
Tue Aug 25, 2015 8:10 pm
Post Re: upper bushing temps
I built a long tail and the upper bushing got hot as hell and I run it like I stole it and never had a problem out of it!
Your motor may be out of align or something.
Sent from my beeper
Tue Aug 25, 2015 8:13 pm
Ok thank you for the reply, go devil said it runs warm I checked it with a inferred temp gun & got 180 degree out of it granted thats on a stand & not in the water slowing the rpm down a little.
Tue Aug 25, 2015 8:58 pm
Let one of the veterans chime in because I don't know much about longtails.
Sent from my beeper
Tue Aug 25, 2015 9:22 pm
The only thing you can do to cool em down is to add more grease!!! I wouldn't think 180 is too hot. Roller bearing get that hot. That's the equivalent to the warm setting on your oven. Which if you've cooked before, ain't hot enough to cook
Sent from...wait, Where am I?
Wed Aug 26, 2015 5:02 am
Dont worry about until the paint starts to come off
Wed Aug 26, 2015 10:30 am
Don't worry about it even if it flames up. Flames make things go faster.
Wed Aug 26, 2015 12:39 pm
Wed Aug 26, 2015 2:36 pm
Hell, during teal season everything is 180 degrees. My ballast up front is a full cooler.
Wed Aug 26, 2015 5:59 pm
Ok thanks guy's! Ill just run er!
Thu Aug 27, 2015 6:27 am
Hot to the touch but cool enough to not melt the seal is ok.
Sat Aug 29, 2015 10:34 am
cron
