It is currently Thu Apr 09, 2026 9:08 pm
Reply to topic  [ 64 posts ]  Go to page Previous  1, 2
 Lever style throttle , 30$ , 20 minutes
Post Re: Lever style throttle , 30$ , 20 minutes
Weve trimmed up a few cables and put a furrel on the end for a stop
1436 Lowe
Fri May 23, 2014 10:12 am
That too will work. Also can go to hobby shop and buy set screw barrels. Like what you would use to keep wheels on Landing gear on a model airplane
Fri May 23, 2014 2:28 pm
Tue May 27, 2014 6:47 am
Did you have to adjust or replace the recall spring on the motor? I want to do this mod to mine, but don't think the existing spring will work. I was wondering how you handled that on yours?
Tue Jun 10, 2014 9:59 pm
Yes added a heavier return spring so it would return to idle when your not on the gas .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Wed Jun 11, 2014 6:26 am
Wed Jun 11, 2014 6:30 am
Got it done. Took a while and had to modify the handle, but only spent $22 bucks.
Thu Jun 12, 2014 9:08 pm
Thu Jun 12, 2014 9:10 pm
The factory one was stock go devil. , like on your lawnmower , push forward or pull back , usually needing two hands , with the return spring pulling back tension , I drive one handed and accelerate or decelerate as needed , it works for me .
H Finn
BACKWATER PROSTAFF
Thu Jun 12, 2014 9:14 pm
ahh my bad. totally forgot about that
Thu Jun 12, 2014 9:38 pm
Fri Jun 13, 2014 5:05 am
I will try and get a pic of it tonight, but all I did was cut the cable clamp off the stock throttle leveler with a grinder. It fit perfectly in the new handle and was so rusted i couldn't get it off anyway. If I ever decide to go back to stock I will replace the whole assembly. Hope that helps.
Fri Jun 13, 2014 8:41 am
These are the ends you can put onto the cable for the handle. You can get them in several different sizes and they're cheap like under $3 for a set of 4. Good luck and hope this helps
Mon Jun 23, 2014 8:06 pm
Tue Jun 24, 2014 5:13 pm
Wed Oct 29, 2014 1:30 pm
BACKWATER PROSTAFF
Wed Oct 29, 2014 2:46 pm
I still have the factory GD throttle and really don't see what the rave is all about with the brake lever throttle. I like to have my cruise control so I can sit down and run. On long runs I like to sit and drape my arm over the stick to keep the boat straight. I have no problem running my throttle with one hand. All you have to do is wrap your pinky over the top top operate the throttle and the rest of you hand to hold the tiller.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Oct 29, 2014 9:57 pm
Got mine done
23 go devil long tail pushing a bloody feathered 17 ft wreck
Sun Nov 02, 2014 3:44 pm
Really like it
Sun Nov 02, 2014 3:47 pm
Looks good , you'll really enjoy it.
H Finn
BACKWATER PROSTAFF
Sun Nov 02, 2014 4:14 pm
I used the recommended lever on my 35 GDLT. If I set the throttle cable so I get WOT it won't idle down. If I set the cable where it will idle properly I only get 3000rpm WOT. Does this mean I'm not getting enough travel?
Tue Dec 13, 2016 7:42 pm
This is an old thread , it worked but full travel was an issue . I eventually moved the whole lever further out as I changed motors and needed further travel. From 16 hp to 25 hp then 23 hp . I achieved this by using a thick dowel rod to mount lever on then mounted about a. 1-1/2" piece on actual handle for full travel . It's not ideal but it worked .Ive since switched to a superior designed full travel lever , bps ,that was all on my gdlt frames , that's what's on my backwater now. Get one of those and forget about travel length worry.
H Finn
BACKWATER PROSTAFF
Tue Dec 13, 2016 8:55 pm
Thanks for the reply. Do you use the factory throttle cable with the BPS lever?
Sat Dec 17, 2016 8:13 pm
15/42 Alweld 25 MBLT
Sat Dec 17, 2016 8:40 pm
