It is currently Wed May 14, 2025 1:20 am
[ 7 posts ] |
TEXLADUCKSLAYER
 RPM and Speed question
I have a light modded 23lt and I am turning 3850 in water with a 9x7 running 22mph and turning a 9x6 4000 running 22mph....any ideas???? Am I topped out or can I get more?
Wed Aug 03, 2011 1:31 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
With those props I doubt you will get anything higher. You are probably running about 20-21 at 3600 and then that. I think you are at the top of the curve right now.
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
Wed Aug 03, 2011 3:10 pm |
TEXLADUCKSLAYER
 Re: RPM and Speed question
So would getting someone such as Hopkins to tune up a prop to say 9x8 or 9x9 help any?
Wed Aug 03, 2011 8:00 pm |
kibb
Might wanna wait and see if someone with a similar motor chimes in.
Wed Aug 03, 2011 8:03 pm |
TEXLADUCKSLAYER
Ok man, appreciate it. I did go run it again today and added some octane boost and got 3950 and bumped 23 a couple times with 2 of us in the boat...only reason I tried that was I was having a detonation/preignition problem and was trying the octane boost for that problem.
Wed Aug 03, 2011 8:14 pm |
Woodiebuster
What size boat is it on?
Without doing more mods it sounds like you are about peaked out. What have you done to it?
Wed Aug 03, 2011 8:23 pm |
TEXLADUCKSLAYER
Woodie, it is on a 1652 riveted flat with frog spit on bottom. decked heads 15, bored 30 over, polished and 3 angle valve grind, 35 carb, twin exhaust, high flow s&b air filter.
Wed Aug 03, 2011 8:31 pm |
[ 7 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 60 guests |
