| post to end most LT problems http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=22774 |
| Author: | fishon!! [ Mon Oct 03, 2011 7:07 pm ] |
| Post subject: | post to end most LT problems |
ADJUST THE CAVITATION PLATE!!! gets old seein every problem being a simple cavitation plate adjustment. it's there for many reasons, not JUST cavitation... thats all... |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:09 pm ] |
| Post subject: | Re: post to end most LT problems |
my motor keeps blowing out of the water. What do i do? |
| Author: | cb5331 [ Mon Oct 03, 2011 7:10 pm ] |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:11 pm ] |
so what you are saying is that the earths gravitational pull is off causing my motor to defy gravity? |
| Author: | cb5331 [ Mon Oct 03, 2011 7:12 pm ] |
I'm just saying, it sounds like it's broken. |
| Author: | cb5331 [ Mon Oct 03, 2011 7:13 pm ] |
I will give you 63 bucks for it. I can always use extra parts. |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:17 pm ] |
alright well i will hold on to it until the next full moon and see if that helps. i |
| Author: | cb5331 [ Mon Oct 03, 2011 7:18 pm ] |
Maybe if you go outside and stare at for for an hour or so everyday. That seems to work sometimes. |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:21 pm ] |
i'll have to try that |
| Author: | Tenpoint [ Mon Oct 03, 2011 7:21 pm ] |
| Author: | Woodiebuster [ Mon Oct 03, 2011 7:26 pm ] |
Why is mine so slow? I can't plain with 4 people and 8 dozen deeks. The same boat with a 25 Suzuki would plane out... |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:28 pm ] |
woodie you need new piston return springs |
| Author: | SwampDonkey1 [ Mon Oct 03, 2011 7:53 pm ] |
I got a 6.5hp longtail mud motor on a 1654 welded aluminum boat with a 20 inch transom. Im trying to hit at least 20 mph... Would pods help me out? |
| Author: | duckduckboom [ Mon Oct 03, 2011 7:57 pm ] |
yes |
| Author: | duckduckboom [ Mon Oct 03, 2011 8:05 pm ] |
the thing located or the driver side lower rear upper control panel next to the flux capacitor |
| Author: | Woodiebuster [ Mon Oct 03, 2011 8:16 pm ] |
Switch all the wires on the hydraulic clutch, I heard you can pick up a few mph like that |
| Author: | cb5331 [ Mon Oct 03, 2011 8:19 pm ] |
| Author: | SwampDonkey1 [ Mon Oct 03, 2011 8:32 pm ] |
If I take all the foam out of my boat will it still float? |
| Author: | duckduckboom [ Mon Oct 03, 2011 8:34 pm ] |
it will float on the bottom |
| Author: | Glades Ranger [ Tue Oct 04, 2011 3:34 am ] |
You have to get up early enough in the morning, brush your teeth, or the cavitation plate won't work! I say get a pirogue and be done with it! |
| Author: | keys1222 [ Tue Oct 04, 2011 7:29 am ] |
Where do you get piston return springs? i think mine arent stiff enough at 9500rpm |
| Author: | Goose Crumpler [ Tue Oct 04, 2011 7:47 am ] |
^^Harbor freight carries them I beleive.^^ |
| Author: | duckduckboom [ Tue Oct 04, 2011 8:45 am ] |
| Author: | fishon!! [ Tue Oct 04, 2011 1:19 pm ] |
| Author: | cb5331 [ Tue Oct 04, 2011 1:19 pm ] |
There is a dire need for a sarcasm font. |
| Author: | fishon!! [ Tue Oct 04, 2011 3:40 pm ] |
put your float foam on the outside of your boat for best flotation and overall performance, bend your cavitation plate upwards at a good angle to keep the prop from surfacing and speed is really all that matter when it comes to a longtail --sarcasm font-- |
| Author: | BASSMASTER [ Tue Oct 04, 2011 3:44 pm ] |
for reverse just put your prop on backwards! |
| Author: | keys1222 [ Tue Oct 04, 2011 3:56 pm ] |
DDB and BASSMASTER where did you come up with such an idea? |
| Author: | BASSMASTER [ Tue Oct 04, 2011 4:02 pm ] |
the idea just caame to me in a vision! |
| Author: | keys1222 [ Tue Oct 04, 2011 5:32 pm ] |
wish i had those visions |
| Author: | duckduckboom [ Tue Oct 04, 2011 5:35 pm ] |
last time you had one how did that work out? |
| Author: | keys1222 [ Tue Oct 04, 2011 5:42 pm ] |
that wasnt a vision. whole different story there. |
| Author: | sftull [ Wed Oct 05, 2011 9:23 am ] |
I was told to put my lt infront of my boat. They said it would pull better up there. |
| Author: | fishon!! [ Wed Oct 05, 2011 5:19 pm ] |
simple cajuneering boys, no degree necessary why, its elementary, thib... |
| Author: | CTdeathfrombelow [ Thu Oct 06, 2011 10:31 am ] |
The 22 hp LT on my Boston Whaler doesnt go through mud! I think I need a new prop......... |
