It is currently Fri Apr 10, 2026 1:23 am
Reply to topic  [ 6 posts ]
 Galvanizing a longtail
Post Galvanizing a longtail
Looking for a longtail to run in brackish and shallow salt water for were I hunt. I've rarely seen any galvanized longtails out there. Just wondering, how expensive, how hard, and where can you get your frame galvanized if it's not brand new?
Sat Jul 19, 2014 7:12 am
Post Re: Galvanizing a longtail
Don't know the price but there is Saint Mary Galvanizing in Patterson
Sat Jul 19, 2014 2:27 pm
Back water had some when I picked up my motor. No idea about doing it on a used one.
35 Swomp on a 17-52 Alweld on a crusty old trailer you probably shouldn't follow too close
10hp Swomp lite 14-36 alumacraft
Sat Jul 19, 2014 3:38 pm
I galvanized a whole lot of Go-Devil frames when I was in the business, mostly long tails. Not sure why you can't find one but...... to galvanize a painted frame you will need to take it all the way down. That means no grease fittings, no bushings, no nothing just the shaft tube with the frame welded on. You will need to remove all paint & grease from the frame also welding flux (may be present & painted over must be mechanically removed). After you get it back you will need to "clean" excess zinc to reinstall grease fittings and re-install bushings. Before you start the process make sure you can find a galvanizer that takes small jobs and does not have a big minimum charge.
17' CAT 5 with 37 GTR
Sun Jul 20, 2014 1:48 pm
I'm sure they don't sell just the frame, but Go-Devil sell long tails with galvanized frams.
17'Extreme Metal Fab. Skiff - 23 GDLT
Sun Jul 20, 2014 5:21 pm
Yea ended up finding one, there just weren't a lot on the market for a few days
Sun Jul 20, 2014 11:16 pm
