It is currently Fri Apr 10, 2026 12:57 am
Reply to topic  [ 22 posts ]
 So what's new in the world of long tails
Post So what's new in the world of long tails
Any thing new for 2015
Mon Jan 12, 2015 8:28 pm
Post Re: So what's new in the world of long tails
Backwater has the 37EFI.
Mon Jan 12, 2015 8:32 pm
Yeah been hearing everybody talk about the 37EFI
Mon Jan 12, 2015 8:53 pm
Those 35 SWOMP's are a tempting setup. Debating on upgrading my 27 Go-Devil to the 35 SWOMP this year. Part of me just wants to build a high HP setup and give it a go similar to the old Predators
Tue Jan 13, 2015 7:57 am
Tue Jan 13, 2015 8:08 am
Tue Jan 13, 2015 8:30 am
If I could find a predator to buy I'd scoop one up also.
Tue Jan 13, 2015 12:13 pm
Not much new to longtails because its hard to improve on perfection
23 go devil long tail pushing a bloody feathered 17 ft wreck
Wed Jan 21, 2015 4:44 pm
Thu Jan 22, 2015 9:30 am
I would like to see new or improved designs on hulls, meaning not everyone needs a .125 tank :mrgreen: meaning lighter weight but still structurally sound hulls, meaning more LT friendly (no obstrusive seats, better attachment points). I would like to see some propeller advances....I tried the GD 3 blades prop back in the late 80's when they introduced them and they were fine in clean water but knotted up with veggies...but I see some are now standard on surface drives. BackH20 is to be commended for the new paradigm in longtails...I see plenty of small and large rigs in southeast Asia that are pushing heavy loads with amazing speeds, many piloted by skinny operators while all I eve hear is whining from former LT owners here! :ugeek: I've been toiling with LT's since 1987, my arm is holding up fine, I want to go from a 27 to a 35 HP for better push, torque, speed when I am carrying three hunters and gear. I'd like to see more user-friendly grips, throttles, better grease zerks for the shaft housing, hex hub props for easier removal/assembly, fold-away grab bar, more efficient (and affordable) mufflers, refinements in motor mounts to reduce vibration, easier-to-work on bearing systems...just to name a few. :mrgreen:
Thu Jan 22, 2015 12:56 pm
+1 on the better longtail hull design been a quest of my for past few years
Thu Jan 22, 2015 2:37 pm
Wed Jan 28, 2015 12:42 pm
wise1, absolutely right about the beauty/efficiency of the longtail design...27 years and it has been the best duck hunting tool in my arsenal, apart from the vacuum coffee mug I bought.
Wed Jan 28, 2015 3:30 pm
Being a veteran long tail owner- user i have had one on a bateau, one on a go devil boat and now have a 20 on a homebuilt skiff, (14.5 ft by 44 inch) i wish they would run flateer on plane. I had a 27lt on a 16x38 go devil boat and is just would not lay down. I wonder if transom angle would help, Warren recomends a long boat to combat this but there has to be another solution. some of the places i go an 18 foot boat is not an option.
Sun Feb 01, 2015 12:08 pm
Backwater has a new glider light (straight shaft) kit for the bigger vtwins. I believe you can go upt to 27-28 HP with them. I got the 1st production model October of last year.
18x50 DFOU custom hull,
backwater kit with gx670 honda,
Robertson exhaust kit,
Work in progress
Mon Feb 02, 2015 9:34 pm
Tue Feb 03, 2015 7:54 pm
Wed Feb 04, 2015 12:01 am
I've thought about building a remote transom mount of the back of my Go-Devil 1856 to get some of the handle out of the boat and also mount it about 6" lower than the current height to correct the prop angle.
Wed Feb 04, 2015 8:24 am
Wed Feb 04, 2015 4:04 pm
Hey, Frank! I believe you about the 37 EFI except Backwater does not display this on their site. Is the extra 2 HP on the same weight block? Wow! I am licking my chops, even though I have to wait a season or two.. It is hair raising when I hit 20 mph on my rig when I ride alone but sustaining that with two hunters and gear will be nirvana! Vroom, vroom! Be nice if the SS muffler came standard, but I believe it is worth it. Thanks for the update. I have to repair my bearings, shaft, etc., but I am presently focusing on spring turkey season! :mrgreen:
Thu Feb 05, 2015 7:40 am
Thu Feb 05, 2015 8:34 am
Thu Feb 05, 2015 8:44 pm
