It is currently Fri Apr 10, 2026 7:08 am
Reply to topic  [ 8 posts ]
 Lowe 1440M or Alumacraft 1542???
Post Lowe 1440M or Alumacraft 1542???
I just bought a used 16hp vanguard go-devil and now I need a boat. I would like a welded 14ft flat bottom but can't find any for a decent price. So the question is do I go with the riveted Lowe 1440m or Alumacraft 1542?
It'll be used to either hunt 2 people and a dog or transport 3 people and a dog plus gear, though gear is a minimal amount. I already plan on getting pods installed as well by a local fab shop. I won't be doing much open water traveling, especially if the weather is bad. It'll be primarily for backwaters on lakes here in Texas.
I just don't know if the extra 1ft length and 2in width would be better than the mod v on the smaller boat. The rest of the specs are fairly the same.
Any input is appreciated.
Thu May 29, 2014 7:39 pm
Post Re: Lowe 1440M or Alumacraft 1542???
1543 flat will be better for sure.
Fri May 30, 2014 11:19 am
Alright thanks for the help! Any particular reason you say that? I'm new to the whole mud motor scene so I'm just curious.
Fri May 30, 2014 7:21 pm
Go with the 1542. You will appreciate the extra foot and 2 inches of width. If its a flat front and your wanting a V then have your fab shop weld a duck bill to the front. You will never have a boat with too much room so bigger is always better.
1542 War Eagle with 25hp GDLT
Sat May 31, 2014 8:10 am
Also if your looking at those boats brand new check out w eldbilt boats. They are all welded and I believe the prices are better. Backwoodslanding.com has the best prices
Sat May 31, 2014 8:14 am
Ok thanks for the help! Will the extra foot cause much of a difference speed/performance wise? I know a good prop is the biggest factor but I'm curios about the boats effects.
Thanks
Sat May 31, 2014 8:22 pm
If anything you will be faster with the extra foot of length the boat will ballast less water.
Mon Jun 02, 2014 11:49 am
1542 extra length will plane better than a 1440 all day and prob end up being a little speeder
Sun Aug 24, 2014 8:28 am
