It is currently Fri Apr 10, 2026 8:51 am
[ 6 posts ] |
jarnotski
Joined: Thu Mar 06, 2014 12:45 pm Posts: 7 Location: Bemidji, MN
 battery for SWOMP 23
Picking up my SWOMP 23 (my first LT!) for my 1448 in a couple weeks. What is the smallest size battery you guys recommend for this engine (vanguard). Want to get the smallest possible in the interest of minimizing weight.
Thanks,
| Thu Aug 14, 2014 3:35 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: battery for SWOMP 23
Congrats on the swomp , you'll love it , you could use an actual lawnmower battery , it is a lawn mower motor . But most use a 12v 650cca or bigger for starting and running other accessories .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Thu Aug 14, 2014 4:32 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
I agree with huck, you need to get enough cranking amps! On the plus side, your 23 is probably equipped with a recoil start- have you tried starting the motor with that? I know I don't have one on my 27 Kohler LT so if my battery runs down I am out of luck. I have a marine starting battery, 850 cca because I run the lights, the bilge, and sometimes a trolling motor (not during duck season) and the weight of it up front helps to balance my rig. If you do go the lawmower route, I suggest getting two- the weight would still be a bit less than one large battery, or one plus an emergency start box. Can you start your 23 with the recoil pull start and NO battery? Let us know how it goes.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Fri Aug 15, 2014 4:30 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
I use a lawnmower battery and keep a spare onboard.
_________________ 23 swomp/ 1542 tracker
| Fri Aug 15, 2014 10:59 am |
jarnotski
I'm pretty sure it has pull start. I don't think I'll be running any accessories. What shoud the minimum CCA's be for just starting?
| Fri Aug 15, 2014 7:40 pm |
Honky Kong
Joined: Fri Feb 22, 2013 3:41 pm Posts: 227 Location: Mankato, MN
I run my Swomp 23 with a 750 cca deep cycle. The pull start is a great feature and was a selling point for me. You can run with no battery if you want/have to. My luck, my battery will go to hell in the middle of nowhere. If you are running lights and other accessories go with a good deep cycle. No accessories, I'd still get a good deep cycle that way you have enough battery should you change your mind and add nav lights, head lights, 12 volt outlets, radio etc. Those few amenities are nice to have.
_________________ Backwater Swomp 23 / Lowe L1448M
| Sun Aug 24, 2014 12:03 pm |
[ 6 posts ] |
