pete1004
 23 swomp vs 23 mb
Which motor would you guys recommend for my tracker 1448? It will mostly be 2 of us hunting with a small hunting load (close to 400 lbs for all).
| Thu Nov 06, 2014 9:42 pm |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
 Re: 23 swomp vs 23 mb
Swomp
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
| Thu Nov 06, 2014 9:43 pm |
pete1004
What kind of speeds do yall think I would get? I would go with the short shaft motor
| Thu Nov 06, 2014 10:01 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
What height is your transom , 59" for short transom boats. , ss , 72" for tall transom boat s ,Ls . I run a swomp. 23. ( modded stage II. ) on a. 15 x 36 godevil duck skiff , stock I was running 19-20 . But definitely suggest the backwater over any other longtail .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Thu Nov 06, 2014 10:06 pm |
pete1004
It's a short transom so I would run the 59
| Thu Nov 06, 2014 10:08 pm |
huck Finn
Frank the tau ran a stock 23 swomp ss on his war eagle boat and ran same 19-20 range . Longtails typically like long skinny boats , yours would be shorter and wider but speeds should be compareable. , is it a true flat bottom .
H Finn
| Thu Nov 06, 2014 10:12 pm |
pete1004
No, I have rails on bottom
| Thu Nov 06, 2014 10:17 pm |
huck Finn
Be similar to franks war eagle . Good luck .
H Finn
| Thu Nov 06, 2014 10:19 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
Been there. Done that. Got the T shirt.
You're doing yourself a disservice if you don't go with the SWOMP.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Fri Nov 07, 2014 12:43 am |
