It is currently Tue Apr 07, 2026 2:54 am
Reply to topic  [ 6 posts ]
 24hp beavertail u joint
Post 24hp beavertail u joint
I am looking for a part number or something I can cross reference for the size of the u joint used on a 2000 24 honda beavertail. Tried contacting beavertail with no reply. Just looking to save time pulling and running around town
Thanks
Josh
Thu Oct 30, 2014 11:32 am
Post Re: 24hp beavertail u joint
Huck finn can you help this guy?
Tue Nov 04, 2014 2:08 pm
These are the part #'s from Beavertail.
94120 U-Joint,
3/4" for 6 Hp
94140 U-Joint
1" for 13 HP
94130 U-Joint
1 1/8" for 20-
35 HP
If you call them they will usually answer. I think the 94130 is around $80 from them.
Thu Nov 06, 2014 3:59 pm
Pull the U joint and take it to NAPA or another parts house and tell them you need a new one.
Thu Nov 06, 2014 6:30 pm
Wing dam is correct. 94130 is the part # you want. I had a 2002 beavertail and that is the one I ordered. The 24hp honda motor has the 1 1/8" diameter shaft. If you want to double check just look up the motor specs online or in the manual
Fri Nov 07, 2014 6:40 am
You are crazy if you pay $80 for a u joint. $12 at a parts store.
Fri Nov 07, 2014 8:01 pm
