It is currently Thu Apr 09, 2026 9:04 pm
Reply to topic  [ 10 posts ]
 Generac 33 hp and SWOMP kit
New Member
Post Generac 33 hp and SWOMP kit
Will a generac 33hp work with the SWOMP kit. Just wondering if it will handle the higher hp motor and also how the tapered shaft would work. I'm new with this mud motor stuff so any input would be nice.
Tue Aug 19, 2014 11:40 am
Post Re: Generac 33 hp and SWOMP kit
Power731 on here ran a 33 Generac on a 35hp SWOMP frame.
Tue Aug 19, 2014 6:05 pm
Thu Sep 04, 2014 7:24 am
What sleeve is this that turns the tapered shaft into a straight shaft?
thanks
1442 Polar Kraft/ 20HP Beavertail LT
Sun Oct 12, 2014 9:38 pm
Fri Jan 30, 2015 12:14 am
Tommy, what kind of numbers are you getting with the Generac 33? MB had them for a short while but I've never read any reviews from the field. I have to overhaul my 27 HP before next season...have to budget for a swomp.
Fri Jan 30, 2015 7:14 am
Is this the engine you guys have used?
http://www.brandnewengines.com/0H0684.aspx
No issue's with being a fixed speed generator engine? Ie, easy to hook up a throttle cable?
Thu Feb 05, 2015 2:49 pm
Almost every industrial vtwin engine is designed to run fixed apeed 3600+/- all day long.
But dont buy that one it has a tapered shaft. You need to look for a 0054420srv model. Its got 1-7/16 shaft but 1-1/8 shafts part # 0E4357G are easy to find and is a direct swap. Guess you could buy the taper shaft and swap also.
Here this website can save you a few hundred dollars also.
http://www.m-and-d.com/GEN-0054420SRV.html
Fri Feb 06, 2015 4:00 pm
Fri Feb 06, 2015 4:53 pm
Since this is longtail talk yep im sure you can get a u-joint that is 1-7/16 x "x" pending your drive shaft diameter. That should be easy.
Fri Feb 06, 2015 10:52 pm
