bushwacker34
 Speed!! MPH
Provide following: (1)boat make/size/flat or mv (2)motor HP/ brand/ longtails only! (3)prop size/# of blades If your feeling frisky....(4) RPM's and load out
| Fri Aug 26, 2016 6:19 pm |
FL_waterfowler
Joined: Tue May 24, 2016 2:14 pm Posts: 108 Location: Pensacola, FL
 Speed!! MPH
1542 Alweld 25 MBLT 9x7 worn slightly Turning 3750-3800 in water
Solo seeing 21-22 Loaded seeing 17-18
Sent using smoke signals
_________________ 15/42 Alweld 25 MBLT
| Fri Aug 26, 2016 6:30 pm |
flint87
 Speed!! MPH
Some douche already had a thread like this before he was banned... 1860 GDB 35 GDSD Stock prop Turning about 3900-4100 Solo 28 2 men 26 3 men a loaded 45 qt yeti two batteries and 12 gallons of fuel 25 mph bumping 26 Motor has cam, heads (.040), Mikuni and a gutted stock exhaust. Carb is not tuned right, will update speeds after I borrow an a/f meter from Russ.
| Fri Aug 26, 2016 6:59 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
 Re: Speed!! MPH
Shouldn't this just only be longtail speeds?
| Fri Aug 26, 2016 7:10 pm |
flint87
 Re: Speed!! MPH
| Fri Aug 26, 2016 7:18 pm |
flint87
 Speed!! MPH
I'll add something constructive though. Had a 1844 godevil boat 25 godevil longtail 9x6 prop No mods 18 unloaded 16 loaded real heavy. Miss that boat. it would go anywhere and I could push it on dry sand bc it was light and had steel flex on bottom
| Fri Aug 26, 2016 7:21 pm |
bushwacker34
 Re: Speed!! MPH
Flint87, guess another douche is here! I don't discriminate, if you want to talk about your S(short)D(dick), go ahead. This is open to whoever wants to comment. I've looked for a thread comparable but struck out.
| Fri Aug 26, 2016 7:52 pm |
bushwacker34
 Re: Speed!! MPH
BERNIE255
 Re: Speed!! MPH
Just shows how lazy you are, theres a reviews section that has 100s of boats with clear info of what you are looking for.
| Fri Aug 26, 2016 7:58 pm |
Russ
 Re: Speed!! MPH
If you want sd speeds, you should post in the cyber mudfest section, not the longtail. This is however the perfect spot for longtails. Be prepared for some lying, as apparently speed is something worth telling some fits about. Also, flint wasn't calling you a douche. He was referencing one that actually had attempted to collect and post information related to your thread topic, but he's now banned.
What the hell is with all the sensitivity turn butthurt lately because someone can't understand what was posted. Yet another that has been here less than a couple weeks going off because of some perceived slight.
| Fri Aug 26, 2016 8:00 pm |
bushwacker34
 Speed!! MPH
The great philosopher *russ* has spoken! I'm in law enforcement, you think I get butthurt? Bernie* Lazy, maybe, or possibly a little intoxicated on my night off after dealing with stupid ass people all week! My bad. You'd think I posted on the gymnastic page my niece follows. Your right I was comparing all and will move it too the main page. Your right I've been here less than a week, but I've ran a motor for a few years. Not an expert but not a green horn either.
| Fri Aug 26, 2016 8:19 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: Speed!! MPH
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Fri Aug 26, 2016 8:30 pm |
flint87
 Re: Speed!! MPH
| Fri Aug 26, 2016 8:37 pm |
Mark F. Cheney
Joined: Sat Mar 07, 2009 9:44 am Posts: 154 Location: Bountiful, Utah
 Re: Speed!! MPH
love this forum! The cool and the sometimes not so cool. Thank you gentlemen.
Mark F. Cheney
_________________ on the Great Salt Lake marsh
| Fri Aug 26, 2016 9:02 pm |
bushwacker34
 Speed!! MPH
I love it too....now that I know the rules. Everyone keep answering unless it's something other than a longtail!
| Fri Aug 26, 2016 9:16 pm |
stu
Joined: Wed Mar 16, 2011 2:35 pm Posts: 608 Location: Deerfield Beach FL,
 Re: Speed!! MPH
18/48 Alumitec
35 Backwater LS
9/8 prop
37-3800 RPM's
19 empty 17 with a hunt load and 3 people
_________________ Swomp 35 on an 1848 Alumitec Custom
| Sat Aug 27, 2016 6:11 am |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
 Re: Speed!! MPH
Everybody here stretches their "longshaft" a bit. 2004 1648 tracker grizzly mostly flat 2016 26.5 EFI Backwater SS 59" 9x7 prop stock tops out at 3850 rpm 20.4 mph just me (205) and gear Would love a custom 1844/1848 true flat hull. Best thing I did this year was buy the BW and put slick pads on the trailer bunks!
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
| Sat Aug 27, 2016 6:13 am |
Russ
 Re: Speed!! MPH
Interesting. Never been called a philosopher, not even sarcastically. Thanks for that.
1652 (heavy for size) MudBuddy w/24 hp honda 9x6 No clue on rpms 18 solo, 17 with 2 and all the hunt stuff. 15 with 3 and hunt load, close to not planing. 9x7 19 solo, would barely plane 3, so probably 14. Shallow water, both props did fine with 3 and picked up a little speed.
| Sat Aug 27, 2016 6:35 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Speed!! MPH
1548 Weldbilt semi V (4*) 72" MB Longtail 20hp Honda with mild mods Heavily cupped 9x4 prop 4500ish solo, 3900-4000 w/hunt load and two men 20mph when the stars aligned, 16-17 with load. (2 men, several doz decoys, guns, etc)
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Sat Aug 27, 2016 9:29 am |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
 Re: Speed!! MPH
1854 prodigy flat bottom 37hdr 12x10 big blade worn to hell RPMs are high due to worn prop I've had her up to about 78 mph on the interstate but I know she had more left in her!
| Sat Aug 27, 2016 9:32 am |
Flattyphil
Joined: Wed Aug 12, 2015 8:14 pm Posts: 61 Location: So. East nebraska
 Re: Speed!! MPH
1971 Johnson corp 14x44 flat bottom 1989 15hp go-devil 9x3 go-devil prop Bumped timing, stock (vangaurd) 23hp camshaft slightly gutted muffler 6 gallon tank, small battery, lawn chairs, fishing gear, 5 gallon bait bucket me (185) my son (60's) 2anchors. Avg mid teens in the small rivers we fish. 3200-3400 cav plate under water 3600-3700 on the surface of the water.
_________________ 14x44 riveted flat bottom jon pushed by old skool hopped up 15Hp GDLT.
| Mon Aug 29, 2016 11:14 am |
NinjaButtpirate
 Speed!! MPH
2003 GD 18/44 2005 MBLT 72" 29 vanguard Before foam removal BPS 9x6 3600-3700 rpm 15 mph Average hunting load
| Fri Sep 02, 2016 11:05 pm |
NinjaButtpirate
 Speed!! MPH
Took the 18x44 out yesterday.... After foam removal.... Peak speed was 18.7mph..... Avg speed was 17.6mph...... Fighting current, held a solid 17.2..... Turns 3600-3650
| Tue Sep 06, 2016 11:13 am |
joshuabwells
 Re: Speed!! MPH
I'm running a 16x48 alweld flat bottom boat with a stock 22hp 670cc Predator motor on a mayhem mud motors longtail frame and cruise solo with a dog at 18mph and knocking on 20mph when I get on it.
I will be curious to see what it does with a hunt load
huck Finn
 Re: Speed!! MPH
Go devil duck skiff 15' x 36" 2005 model Backwater swomp ss frame , 23 built stage 2 block 13' model Speeds 26-27 mph with 9x8 backwater prop Speeds 24-26 with 10x5 backwater prop 9x8 is my ride prop, 10x5 is my hunt prop.
And yes folks on here have seen and will verify these speeds. She fast, for a longtail.
Huck
| Tue Sep 06, 2016 12:31 pm |
Glades Ranger
 Re: Speed!! MPH
I know that is legit, Huck, you are the paradigm! I just entered the 20 mph club, lost my hat to prove that, sure is fun!
| Tue Sep 06, 2016 2:09 pm |
TwinLT
 Re: Speed!! MPH
16/56 weld built Twin 18hp gd lt No clue on rpms 18 no matter me or 4 an hunt gear
_________________ 16ft by 56 custom weldbuilt with twin 18hp godevil longtails
| Mon Sep 19, 2016 8:55 pm |
Frog
 Re: Speed!! MPH
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
| Tue Sep 20, 2016 4:34 am |
Frog
 Re: Speed!! MPH
Another one
| Tue Sep 20, 2016 5:26 pm |
Teal1Florida
 Re: Speed!! MPH
1648 Lowes Semi V 27hp Mud Buddy Longtail 20mph Solo Rider 17-18 Mphtwo with gear
| Wed Sep 21, 2016 7:07 pm |
Teal1Florida
 Re: Speed!! MPH
redlined_b16a
 Re: Speed!! MPH
1448 monarch,flat bottom with gunnels 25hp Kohler Command Worn 9x7 20mph solo 15mph 2 people with alot of gear Hull about 200lbs,tools 60lbs,spare homemade outboard motor just incase weighs about 100lbs Passenger weighs 180lbs,I weigh 170lbs. Installing a tach cause I think my rpm in water is low.
| Wed Sep 21, 2016 7:23 pm |
FL_waterfowler
 Re: Speed!! MPH
| Thu Sep 22, 2016 8:26 am |
toddh
Joined: Wed Jan 14, 2009 2:00 pm Posts: 428 Location: Hammond, LA
 Re: Speed!! MPH
Old boat:
17 x 45 Geaux Custom 25 HP Kohler 25 GDLT Don't remember prop size Don't know RPM Only me (205) Empty load 24-25 mph 3 man hunting load 17-18 mph
| Thu Sep 22, 2016 8:40 am |
USXC
 Re: Speed!! MPH
| Thu Sep 22, 2016 11:13 am |
Russ
 Re: Speed!! MPH
Nah, we just toss some water at his boat to watch his eyes get really big [SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
| Thu Sep 22, 2016 11:18 am |
igotit
 Re: Speed!! MPH
Heres redlines load(no pun intended)
When i left the dock today
And after a dead battery in lake long the spare motor chugged me outta lake long. Just slide the 25 over.
| Sat Sep 24, 2016 6:55 pm |
Burch
 Re: Speed!! MPH
A solar charger?
| Sun Sep 25, 2016 1:27 pm |
igotit
 Re: Speed!! MPH
Helps keep the battery charged up,it can fully charge a dead battery in 8 hrs.....only if theres sunshine.
| Sun Sep 25, 2016 1:35 pm |
FL_waterfowler
 Re: Speed!! MPH
That's the most interesting load out I've ever seen
| Mon Sep 26, 2016 4:04 pm |
