It is currently Sun Apr 12, 2026 3:53 pm
Reply to topic  [ 4 posts ]
 Mud motor charger/tender?
Post Mud motor charger/tender?
I have an older Sears battery charger that works but must be monitored. Do any of you use the WalMart Battery Tender? I need something that will work for both the boat marine starting battery and the popup camper battery (same); trying to stay within budget of something around 50$. Suggestions please!Thank you!
Thu Jul 02, 2015 4:52 am
Post Re: Mud motor charger/tender?
I used this one before, seemed to the job fine. It's $20 and you can print out a 25% off coupon online.
http://m.harborfreight.com/12-volt-delu ... 20provided
Thu Jul 02, 2015 6:02 am
Thanks, I found good reviews on that on a similar Black&Decker tender, both around $20, seems well worth it.
Fri Jul 03, 2015 7:49 pm
Check out the Battery MINDer.
Gator tail
Fri Jul 03, 2015 7:57 pm
