It is currently Fri Apr 03, 2026 2:25 pm
Reply to topic  [ 9 posts ]
 Propane powered motor
Post Propane powered motor
Was driving through my work parking lot and looked over in our recycle bin and say a generator that my company threw in there. It had a 7hp motor on it ( generator itself didn't work, motor had good compression) . Turns out it's a propane powered motor, and I may sound totally stupid asking this but has anyone ever mad a lt with a propane motor? I was going to take the generator just to hold onto the motor but I didn't know if I was just going to be adding junk to the shed or if it would be useful
Mon Sep 14, 2015 4:28 pm
Post Re: Propane powered motor
I would say you could get a carb for it and run it off of gas.
What kind of motor is is?
Mon Sep 14, 2015 4:30 pm
Honestly idk it was green I never saw the name on it. It'll it was a Honda or some well known name brand I would have grabbed it
Mon Sep 14, 2015 4:58 pm
Years ago Briggs and Stratton made a conversion kit to change from gas to propane. Im not sure if it was a complete carb or just special jets designed for propane.
Mon Sep 14, 2015 6:01 pm
The Subaru eh90 and 99 have lp setups for them for generator usage. Uses a higher compression piston and few other parts.
Mon Sep 14, 2015 6:11 pm
I have a propane ice auger and love it!
Mon Sep 14, 2015 7:20 pm
My cousins is considering a 35hp for his lt and running it off of propane to avoid ethanol. I see mowers all over the place using them.
Mon Sep 14, 2015 7:25 pm
Genie lift equipment can run off of propane or unleaded. There's no switching stuff out so maybe you could get lucky and not have to change anything with that motor. That'd be great if they all worked that way
Pretty sure most of MMT is humusexshuls in hiding
Tue Sep 15, 2015 10:23 am
Hi, try this web page: USCARB.com , the have the kit you need to make it work with propane.
Good luck
Tue Sep 15, 2015 11:12 am
