It is currently Fri Apr 03, 2026 12:31 pm
Reply to topic  [ 4 posts ]
 Swomp question
Post Swomp question
I have a 35 swomp on order and I'm pretty sure I'm gonna hate the throttle lever and I was wondering if any of you with swomps are using a motorcycle clutch lever type throttle and if so where did you get it. Backh2o site says the tube for the tiller is 1.1" tubing but all I can find on eBay is levers for 7/8" dirtbike handlebars unless I buy a clutch lever and brake lever with master cylinder for 60 bucks.
Sun Sep 20, 2015 3:42 pm
Post Re: Swomp question
Hi, I bought a 25 Kohler lt from Backwater and because a bad experience with the old motor I replace the throttle lever for a Bike clutch lever and cable. I bought it at Ebay from a company name Buildyourbike.com all for less than $20.00.
The lever is Stainless Steel , for a 1" tubing, and you can make it fit to a 1.1" using a dremel tool on the inside.
Good luck.
Sun Sep 20, 2015 4:15 pm
Thanks man, all the ones I saw that were cheap didn't list a handlebar size but I will check that out.
Sun Sep 20, 2015 5:53 pm
http://www.amazon.com/gp/aw/d/B000GZL3W ... utch+lever
This lever has a plastic sleeve for 7/8" bars. Remove it, it's 1". It's built pretty solid.
Sun Sep 20, 2015 9:12 pm
