| Swomp question http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=63774 |
| Author: | tfd1224 [ Sun Sep 20, 2015 3:42 pm ] |
| Post subject: | Swomp question |
I have a 35 swomp on order and I'm pretty sure I'm gonna hate the throttle lever and I was wondering if any of you with swomps are using a motorcycle clutch lever type throttle and if so where did you get it. Backh2o site says the tube for the tiller is 1.1" tubing but all I can find on eBay is levers for 7/8" dirtbike handlebars unless I buy a clutch lever and brake lever with master cylinder for 60 bucks. |
| Author: | leonides [ Sun Sep 20, 2015 4:15 pm ] |
| Post subject: | Re: Swomp question |
Hi, I bought a 25 Kohler lt from Backwater and because a bad experience with the old motor I replace the throttle lever for a Bike clutch lever and cable. I bought it at Ebay from a company name Buildyourbike.com all for less than $20.00. The lever is Stainless Steel , for a 1" tubing, and you can make it fit to a 1.1" using a dremel tool on the inside. Good luck. |
| Author: | tfd1224 [ Sun Sep 20, 2015 5:53 pm ] |
Thanks man, all the ones I saw that were cheap didn't list a handlebar size but I will check that out. |
| Author: | Russ [ Sun Sep 20, 2015 9:12 pm ] |
http://www.amazon.com/gp/aw/d/B000GZL3W ... utch+lever This lever has a plastic sleeve for 7/8" bars. Remove it, it's 1". It's built pretty solid. |
