It is currently Fri Apr 10, 2026 12:30 am
Reply to topic  [ 4 posts ]
 Help Older Mud buddy jam nut problem
Post Help Older Mud buddy jam nut problem
I think my motor is a year 2000 with a 20th Honda. I replaced the shaft and the jam nut keeps working it's way into the housing and then binds up. Almost like the prop keeps pushing it up the threads. Any ideas on how to keep the jam nut from moving?
Sat Nov 14, 2015 11:30 am
Post Re: Help Older Mud buddy jam nut problem
Loctite, a pair of half height jam nuts, jbweld or a couple tack welds.... (btw, ignore the last two).
Sat Nov 14, 2015 1:20 pm
Sounds like the shaft is actually working further up the U joint. Did you drill an indention on the U joint end of the new shaft for the set screw to lock in to?
Sun Nov 15, 2015 8:33 pm
im having the same trouble with my 20hp go-devil, i followed the manual n still have the same problem. jam nut n prop spin up n shut the motor off. im about to double jam nut the housing side of the prop.
run it hard af or put it up.
1436 flat bottom 20hp vanguard go-devil crawfish 9x6
Sun Nov 22, 2015 4:03 pm
