It is currently Sun Apr 12, 2026 2:53 pm
[ 6 posts ] |
backwater cavitation plate problems
snookfighter
Joined: Tue Oct 27, 2015 9:58 am Posts: 11 Location: Southwest Florida
I ordered cav plate from backwater. Welded on and ran. Having problems keeping prop in water at wot. Both shims or no shims, I still have to keep up pressure on handle to keep in the water. Tried shimming higher but prop would start to cavitate even under water. Any help would be appreciated.
_________________ 1648 Sea ark 670 Predator longtail
| Sun Nov 29, 2015 10:14 am |
TFWaterfowlSAV
 Re: backwater cavitation plate problems
What is your transom height and shaft length?
| Sun Nov 29, 2015 10:44 am |
flint87
You shimmed it both directions?
| Sun Nov 29, 2015 11:32 am |
snookfighter
My transom height is 15" and shaft length is 60". It looks like the back needs to come up more but when I tried, it made it worse.
| Sun Nov 29, 2015 1:35 pm |
snookfighter
Ok, I shot a laser level down the hull. Got the front of plate bracket level and had to shim back to one degree above level. Did not have time to run today. Will put in h2o tomorrow. I am now 1/4 inch higher at back of plate compared to the two shims stacked. Hope this works.
| Sun Nov 29, 2015 4:04 pm |
snookfighter
[ 6 posts ] |
