It is currently Fri Mar 27, 2026 7:33 pm
[ 3 posts ] |
sandybottoms
 Beavertail motor change?
I picked up a beavertail 13hp with a Honda motor on a trade, I like it but it is a little underpowered for my boat.
Question is, does anyone know what is the largest motor that I could replace the Honda with on that model frame, I realize I would have to re-prop it if I can get a bigger motor on that frame. But does anyone know if the 13hp frame will accommodate a 22+hp motor and everything just bolt up and go..?
| Wed Jan 13, 2016 9:19 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: Beavertail motor change?
Start off by measuring output shaft diameter , to see what you have to match , keep in mind keyway thickness. Secondly measure output shaft height from base plate, center of shaft. You can then try to match as close as you can to clone motors . Specs are readily available online . If you find a match. , you'll next have to deal with base plate bolt layout . You can re tap and drill if need be . My originial godevil longtail, started as a. 9 hp crawfish , and ended up a 16 duromax, finally a 16. Vanguard.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Wed Jan 13, 2016 9:38 pm |
sandybottoms
Thanks for the info
| Thu Jan 14, 2016 11:37 am |
[ 3 posts ] |
