| Shaft Collar ?? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=66793 |
| Author: | ScottC [ Fri May 06, 2016 3:40 pm ] |
| Post subject: | Shaft Collar ?? |
Anybody know where I can get a shaft collar with key way and set screws that is 3/4" one end and 1" on other end? |
| Author: | brycecheramie [ Fri May 06, 2016 5:52 pm ] |
| Post subject: | Re: Shaft Collar ?? |
like, a U-Joint? |
| Author: | jc [ Fri May 06, 2016 6:01 pm ] |
Grainger but they are high. |
| Author: | jaycee159 [ Fri May 06, 2016 6:02 pm ] |
Shaft collar is usually just 1 size. Is This what you are referring to? Sent from my iPhone using Tapatalk |
| Author: | ScottC [ Fri May 06, 2016 8:33 pm ] |
| Author: | ScottC [ Fri May 06, 2016 8:37 pm ] |
| Author: | jaycee159 [ Fri May 06, 2016 8:45 pm ] |
| Author: | umahunter [ Sat May 07, 2016 2:18 am ] |
What's it for ??? |
| Author: | ScottC [ Sat May 07, 2016 9:00 am ] |
| Author: | Cajunwannabe [ Sun May 08, 2016 12:54 pm ] |
Buy a 1" x 1" coupling and then put a bushing in on the 3/4" side for your shaft to make it 3/4". I did that one my motor 3 years ago and haven't had a single issue. I took a dremel and cut a notch in it for the key to slide in. If you think a 1" x 3/4" coupling is high price a 1" x 1 1/8" coupling. It was a whole lot cheaper for me to buy a 1 1/8 x 1 1/8 coupling and do the above with a bushing than paying for an odd size coupling. I would stay away from the 3 piece couplings with the plastic spider. My straight shaft is a 25 hp. What size motor are you using? |
| Author: | fireman1293 [ Fri May 13, 2016 11:36 am ] |
http://www.mcmaster.com/#shaft-couplers/=12e84yb |
| Author: | umahunter [ Fri May 13, 2016 7:36 pm ] |
Do you know anyone with a lathe ?? If not maybe you can take it to a machinist and have half of it bored out to the size you need |
