It is currently Wed Apr 01, 2026 4:51 pm
[ 12 posts ] |
ScottC
 Shaft Collar ??
Anybody know where I can get a shaft collar with key way and set screws that is 3/4" one end and 1" on other end?
| Fri May 06, 2016 3:40 pm |
brycecheramie
 Re: Shaft Collar ??
like, a U-Joint?
| Fri May 06, 2016 5:52 pm |
jc
 Re: Shaft Collar ??
Grainger but they are high.
| Fri May 06, 2016 6:01 pm |
jaycee159
 Re: Shaft Collar ??
Shaft collar is usually just 1 size. Is This what you are referring to?
| Fri May 06, 2016 6:02 pm |
ScottC
 Re: Shaft Collar ??
| Fri May 06, 2016 8:33 pm |
ScottC
 Re: Shaft Collar ??
| Fri May 06, 2016 8:37 pm |
jaycee159
 Re: Shaft Collar ??
| Fri May 06, 2016 8:45 pm |
umahunter
Joined: Thu Sep 24, 2009 4:18 pm Posts: 83 Location: yuma AZ
 Re: Shaft Collar ??
What's it for ???
| Sat May 07, 2016 2:18 am |
ScottC
 Re: Shaft Collar ??
| Sat May 07, 2016 9:00 am |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
 Re: Shaft Collar ??
Buy a 1" x 1" coupling and then put a bushing in on the 3/4" side for your shaft to make it 3/4". I did that one my motor 3 years ago and haven't had a single issue. I took a dremel and cut a notch in it for the key to slide in.
If you think a 1" x 3/4" coupling is high price a 1" x 1 1/8" coupling. It was a whole lot cheaper for me to buy a 1 1/8 x 1 1/8 coupling and do the above with a bushing than paying for an odd size coupling.
I would stay away from the 3 piece couplings with the plastic spider.
My straight shaft is a 25 hp. What size motor are you using?
| Sun May 08, 2016 12:54 pm |
fireman1293
 Re: Shaft Collar ??
| Fri May 13, 2016 11:36 am |
umahunter
 Re: Shaft Collar ??
Do you know anyone with a lathe ?? If not maybe you can take it to a machinist and have half of it bored out to the size you need
| Fri May 13, 2016 7:36 pm |
[ 12 posts ] |
