| round chimes vs square? http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=67205 |
| Author: | Ghostly [ Thu Jun 16, 2016 4:45 pm ] |
| Post subject: | round chimes vs square? |
Alright guys my last post before I order my skiff... My last decision is rounded chimes vs square? 16' skiff with 23 longtail... My skiff will be aluminum Round bottom will be 16x36 Square will be 16x38 My question is will a square bottom slide with a longtail? I know they will with a outboard but from my little of experience long tails tend to not plane the hull flat like a surface drive an with the back drafting 3" Im guessing while running 20mph?, will the back still slide around? Running rivers to get into the swamps 15 min rides But idling in 4-10" of flooded timber an cypress swamps An alot of hard bottom...an yes running slus an established trails in shallow swamps Have at it guys! Thanks to all |
| Author: | cb5331 [ Thu Jun 16, 2016 4:51 pm ] |
| Post subject: | Re: round chimes vs square? |
square CHINE |
| Author: | cb5331 [ Thu Jun 16, 2016 4:53 pm ] |
Unless you're planning on getting boat made that incorporates these somehow... But I don't think those will affect turning. |
| Author: | JD145 [ Thu Jun 16, 2016 4:55 pm ] |
Lets not chine in unless we have something constructive to offer guys. |
| Author: | Crews [ Thu Jun 16, 2016 5:48 pm ] |
First of all, who ever said sliding was a bad thing to begin with? Square chines go faster, carry a load better, and track at idle speeds waaay better. Sent from my iPhone using Tapatalk |
| Author: | Ghostly [ Thu Jun 16, 2016 5:54 pm ] |
Chines chines chines Got it Thanks for the feed back on the CHINES so carry load better track better ...good so far |
| Author: | Will [ Thu Jun 16, 2016 5:54 pm ] |
You won't be going fast enough for it to matter... |
| Author: | mizzippi jb [ Thu Jun 16, 2016 6:14 pm ] |
| Author: | cb5331 [ Thu Jun 16, 2016 6:17 pm ] |
| Author: | scarygary [ Thu Jun 16, 2016 6:20 pm ] |
| Author: | dem0001 [ Thu Jun 16, 2016 6:49 pm ] |
| Author: | Russ [ Thu Jun 16, 2016 6:56 pm ] |
It's a longtail. Sliding is easy to control if you do happen to actually make it happen. Don't over think it, yall. |
| Author: | Ghostly [ Thu Jun 16, 2016 8:05 pm ] |
So square chines all the way is what I'm getting so far.. As far as turning in deep water round an square will be what an what I'm figuring...? |
| Author: | Will C [ Thu Jun 16, 2016 10:34 pm ] |
Agreed^^ square chine. That skinny of a boat is gonna draft anyway |
| Author: | lastchance [ Thu Jun 16, 2016 11:00 pm ] |
| Author: | Crews [ Fri Jun 17, 2016 5:22 am ] |
| Author: | dem0001 [ Fri Jun 17, 2016 9:54 am ] |
| Author: | dead animal [ Fri Jun 17, 2016 10:25 am ] |
guys, square vs round was started by some welder who wanted to make more money off his boats. it's a gimmick, just like a huntdeck. lol learn how to drive the boat and it won't matter. that little 16x38 is gonna carve a turn like a sports car either way. good luck on whatever u choose. the real question is why go 16' instead of 18' or 20'. lol |
| Author: | da go get'er [ Fri Jun 17, 2016 11:05 am ] |
| Author: | Cajunwannabe [ Fri Jun 17, 2016 3:52 pm ] |
I could turn on a dime with my round chine GD hull and I can slide out of control with my hard chine wooden boat. There IS a difference. I want my boat to slide tho, learn how to control it and the advantages outweigh the cons. |
| Author: | Ghostly [ Fri Jun 17, 2016 4:03 pm ] |
Cb5331 those are clearly tapered chimes you posted a picture of... I clearly asked about round chimes or square, not tapered.:p |
| Author: | huck Finn [ Fri Jun 17, 2016 6:26 pm ] |
| Author: | Will [ Fri Jun 17, 2016 7:08 pm ] |
| Author: | North LA Hunter [ Fri Jun 17, 2016 8:52 pm ] |
What are these chimes y'all speak of? Sent from my beeper |
| Author: | longboman [ Sat Jun 18, 2016 12:33 pm ] |
Get a sq one. Then if its not what you thought round it off with a file. HA hA couldn't resist! I'm just getting into these things so its all new and fun for me. But on a serious note I would not worry about with a 23 longtail. |
| Author: | cb5331 [ Sat Jun 18, 2016 12:45 pm ] |
Unless its huck finn's 23 longtail. |
| Author: | SETx Longtail [ Sat Jun 18, 2016 1:17 pm ] |
Huck's 23 > all other 23's. Fact. He got the pixie dust mixture juuuust right on that thing. |
| Author: | huck Finn [ Sat Jun 18, 2016 1:24 pm ] |
H Finn |
| Author: | cb5331 [ Sat Jun 18, 2016 2:43 pm ] |
| Author: | Glades Ranger [ Sat Jun 18, 2016 7:16 pm ] |
Ghostly, whatever you get, slap plenty of gatorglide or steelflex on that, and slide like hell! |
| Author: | Ghostly [ Sat Jun 18, 2016 8:27 pm ] |
Glade ranger, already got a g2 glide kit... it will be my 8th boat putting it on my personnel second... H fin, I keep reading bout your 23, on a light load how quick is it jw? R is it just that good in the skinny? |
| Author: | NinjaButtpirate [ Sun Jun 19, 2016 12:06 am ] |
I prefer rounded CHINE, rolls off of stumps pretty easy, doesn't bind up in veg near as bad, slides across the mud easier.... I know you know, long tails don't have the thrust a sd has.... So when turning in crazy stuff... Rounded is better... Just plain open water, square Sent from my iPhone using Tapatalk |
| Author: | rob_E [ Sun Jun 19, 2016 4:19 pm ] |
I prefer square chines. All other things equal....a square chine boat will drafts fewer "s at rest and at WOT it also goes faster 99% of the time. For me sliding while turning my 18 X 54 cc is never an issue. Not saying it won't slide but again it is not a big deal once you learn how to drive your boat IMHO. B |
| Author: | Ghostly [ Mon Jun 20, 2016 6:52 am ] |
At 1 time I had a fiberglass flat with square bottom. It slid with a out board on it but I got use to it an worked the throttle to work the slide, it's a art like a motocycle in a curve, But I will soon see the diffrence as a guy that launches with me has a 38" round bottom 16 ' an I will have the same boat but square. I can see this leading up to batman vs superman senerio as we both will have 23hp longtails but mine will be a swomp! BTW never seen batman vs superman... |
