It is currently Wed Apr 01, 2026 5:30 am
[ 9 posts ] |
bc23
 Modding help
I need some advice to modding my mud motor. I am new..so please bare with me. I have gd 9hp...I like it for the size but I wanted little more power. I ended purchasing a hop kit that came with air filter, hd valve springs, advance timing kit. I also purchased a Robertson torque tube and lastly a bore out/bigger carburetor.
I do not want to remove the governor because I like the protect the engine just in case the prop jumps out of the water.
I was hoping to just installing the exhaust, filter and carb. And leave out the springs and key.
Could I ruin my motor without installing Timing key and springs and leaving stock?
At what rpm does HD valves start to float?
Bc23
| Sun Jun 26, 2016 8:42 pm |
Will C
 Re: Modding help
The springs are to let it rev higher. If you are not raising the governer rpm the yes you can leave them out for now. The timing key being left out will not hurt your engine. That being said , you bought a hopup kit for more power from someone that put a "matching kit" together. Why not just install the kit as its intended? What engine is it anyway? Ive never serviced a GD that small
| Sun Jun 26, 2016 10:15 pm |
bc23
 Re: Modding help
| Mon Jun 27, 2016 3:41 am |
WI WATERFOWL
 Re: Modding help
| Mon Jun 27, 2016 8:32 am |
bc23
 Re: Modding help
| Mon Jun 27, 2016 2:00 pm |
bc23
 Re: Modding help
WI WATERFOWL
 Re: Modding help
Not sure on the single cylinder 9hp. Honestly as soon as you remove or tweak the governor you better have the springs changed or you will likely been getting valve float, if not worse.
| Mon Jun 27, 2016 4:01 pm |
phoneman7
Joined: Tue Jan 13, 2009 7:16 pm Posts: 250 Location: Sumter, SC
 Re: Modding help
Thinking of getting a 9hp myself. What boat do you have it on and what kinda speed do you get? I want one for a lightweight 1436. If i can get 12-14 mph empty id be tickled
_________________ 1638GD with 23GDLT 542 war eagle with 25 yamaha A few pirogues
| Thu Jun 30, 2016 7:11 am |
bc23
 Re: Modding help
| Sun Jul 03, 2016 6:59 pm |
[ 9 posts ] |
