It is currently Fri Apr 03, 2026 4:53 am
Reply to topic  [ 18 posts ]
 Different grease?
Post Different grease?
What grease has anyone used on a GD 23HP longtail besides the red GD grease? I'm thinking any marine type high quality grease should be OK. Anything to definitely NOT use?
GoDevil 18X44
GoDevil 35 SD
Wed Jul 27, 2016 5:54 pm
Post Re: Different grease?
Lucas red n tacky
Wed Jul 27, 2016 6:37 pm
Lucas red n tacky here too. Use it on every boat motor, trailer, vehicle and piece of equipment I own. Doesn't hurt I get it by the case at work. :lol: it's damn good grease.
Wed Jul 27, 2016 7:23 pm
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Wed Jul 27, 2016 8:01 pm
I run the amsoil, starting third year on my trailer and still have no slack in wheel bearings, pump a little before every move and it goes in everything I have that has a grease fitting. just my experience is a little tlc with any grease goes along ways
Wed Jul 27, 2016 10:34 pm
Thu Jul 28, 2016 4:16 am
Green marine grease from autozone
Tue Aug 02, 2016 7:29 am
I use AMS oil and have not had a problem. Very good chemistry in their products. I also use it in all my trailer bearings and hit the grease points with it on my Honda 15hp outboard.
Wed Aug 24, 2016 8:11 pm
I use smitty's red #2 high temp lith grease. No trouble so far!
Thu Aug 25, 2016 9:57 pm
Brylcreem, if you can find it. :mrgreen:
Sat Aug 27, 2016 6:16 am
X3 on da Lucas red n tacky. The Stuff is great! I also use it on everything from tractors to boats
Sent from my SAMSUNG-SM-G890A using Tapatalk
Gen III Pro Drive with a JBP stage 2 pushin 18x54 madmancustom
Jus nut up and grab a handful of throttle
Sat Aug 27, 2016 6:26 am
Sat Aug 27, 2016 12:18 pm
I must have got a bad tube of the Lucas red n tacky because I used it on a trailer when I put new wheel bearings in and that stuff got runny like honey and leaked out of some brand new bearing buddys.
Sat Aug 27, 2016 2:14 pm
Sounds like it. I've been using it for years on all sorts of equipment and never had an issue with it thinning. I replaced my trailer hubs and bearings a couple months ago and haven't seen anything come out of the bearing buddies except for what leaked out the relief hole like it's supposed to.
Sat Aug 27, 2016 2:19 pm
The blue Lucas extra heavy duty is good shit too. We use it on our bobcats and mini excavators at work and they get run hard
Sat Aug 27, 2016 2:30 pm
Just remembered a good one- Aqualube, I think the company is in Ky. If you have some extra dough, Mobil 1 synthetic is very good also; after break-in, or after your first oil change, IMO both synthetic oil and grease are recommendable.
Sun Aug 28, 2016 6:20 am
I run Mobil1 grease in the 5th wheel. Synthetic Rotella 5W-40 oil in the GD and all the other small engines. I'm experimenting with WalMart marine grease in the GD trailer bearings. So far it works good. I can't find that old Pennzoil blue marine grease anywhere.
Lucas Red & Tacky will go in the GD.
GoDevil 18X44
GoDevil 35 SD
Sun Aug 28, 2016 4:47 pm
If I remember correctly, any waterproof #2 grease is fine. But, I always used Aqualube. You won't save any money if you have a bearing failure because of cheap grease.
Wed Aug 31, 2016 9:45 pm
