It is currently Mon Apr 06, 2026 8:56 pm
Reply to topic  [ 2 posts ]
 Need suggestions for mounting my Beavertail on a Tracker
Post Need suggestions for mounting my Beavertail on a Tracker
My Tracker Grizzly has an annoying center beam support so I can't add a transom plate. Would you guys through bolt this? If you look on the backside I can't through bolt from the back since the center support is in the way of the only hole in the back. Right now I have some fender washers and some 5200 and a prayer keeping this thing on. What do you think? I always hate drilling through the transom but..... Thanks guys.
Mon Aug 15, 2016 8:49 pm
Cut that one off and add 2 on either side.
Or cut off enough to where you can drill the hole you need
Tue Aug 16, 2016 3:09 pm
