BigKev99
Re: Speed!! MPH
1442 flat 15hp lifan i have 2 props and i haven't seen that i just thouught of it but they are a 9'' and a 6'' 3600 rpm 500 lbs 20-21 mph
Sat Oct 01, 2016 2:17 pm |
Nbrown89
Re: Speed!! MPH
1542 flat 23hp backwater swomp lite 9x6 prop. 21mph myself, 18 mph 2 ppl and gear.
Sat Oct 08, 2016 5:52 pm |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
Re: Speed!! MPH
1550 havoc, 35 stock GTR, 3 blade prop, deep water right at 37 mph, with 4 people, shallow with same load is 39 mph. this is allwith gator glide and superb driving.
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
Sat Oct 08, 2016 7:13 pm |
aknative
Re: Speed!! MPH
6.5 Predator on small Swamp Runner kit, slightly modified but still governed 1432 Lowe riveted flatbottom 15 up river with one person and a trapping load 19.5 down river with one person and trapping load. Saw 20 and change once, but didn't maintain it. These are at WOT, that rig is more comfortable cruising at 10ish up river and 15ish down river.
Tue Oct 11, 2016 6:48 pm |
22hppredator
Re: Speed!! MPH
Ok guys with predator engines. I have a 22 hp predator engine with a 7x4 prop on a 14 ft john boat motor is mounted on a go devil frame. Loaded or unloaded I run 7-8 mph. Usually I have 2 guys 6 gallon tank battery guns and decoys. I have been watching you tube and reading threads and people are running upper teens to lower 20s. What size propeller do I need to be running. Any help would be appreciated.
Sun Dec 18, 2016 9:32 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Re: Speed!! MPH
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Tue Dec 20, 2016 6:48 pm |
tommy.wheeler.39
Re: Speed!! MPH
I have the same motor as you do and 14 foot v Hull and I two batteries 6 gallons of gas fishing gear cooler for ice soda and beer and 9 inch prop we are transom is 21 inches and I go about 14 miles an hour
Tue Dec 20, 2016 10:18 pm |
ducktank23
Re: Speed!! MPH
14x36 Flat Bottom 420cc Predator with a Beaver Dam Mud Runner 8" Prop 2 Blade Air Intake and jetted carbs Solo pushes about 15-16mph. Loaded about 11mph
Sat Dec 24, 2016 3:09 pm |
mogenduck
Joined: Thu Feb 18, 2016 12:05 am Posts: 71 Location: coral springs ,fl
Re: Speed!! MPH
10x36 Grumman 6.5 predator swamp runner kit 7½x5 19-20 solo 16-17 with the load air intake and oversized jet no muffler
Wed Dec 28, 2016 2:48 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
Re: Speed!! MPH
Wed Dec 28, 2016 3:51 pm |
igotit
Re: Speed!! MPH
14x42 monarch flat 22 subaru 74" shaft homemade frame 9x6 wheel 20 mph solo 18 mph 2 adults
Lite load,cooler 2 deep cycle batteries,small tool box and spare wheels. 2060 rpm @ 20 mph.......too much wheel.
Sat Mar 04, 2017 11:27 pm |
sleepy_sleeper
Re: Speed!! MPH
1548 Weldcraft 22hp Predator (all stock) on Go Devil bushing frame 9x6 Backwater Prop 20mph solo at 3700 rpm 16mph full load at 3500 rpm
9x6 Backwater Prop broken in running shallow salt water 22.3mph solo at 3950rpm 18.5mph fishing load (wife, 2 small kids etc) 3800rpm
9x5 Go devil Prop 18mph solo at 4000 rpm 15mph loaded at 4000 rpm
I'm also burning about 1gph if anyone cares.
Both these speeds are in deeper water with slight chop. Governor spring is zip tied to spin 4200 - 4300 out of the water. The 9x6 will easily break 20mph solo in smooth water and may get low 20s if I can dial it in. If they made a 9x5.5 that would probably be perfect for a stock Predator 22.
Just did some running and updated speeds are posted up above. The motor now has about 20hrs on it and the 9x6 BW prop is broke in after a couple hrs run time. Saw 3-4mph increase in both speeds.
_________________ Go Devil 1860 35 GDSD Weldcraft 1548 22hp Predator GDLT
Sun Mar 05, 2017 2:17 pm |
redlined_b16a
Re: Speed!! MPH
I swapped to a 1973 16x4 riveted thick hull with marine ply floors and front deck . I'd guess 400lbs easy. 18mph solo with gear in deep water against wind.Fastest was 19mph. 25 kohler GoDevil 9x7 prop with alot of miles on it. Im pretty satisified.Never ran with 2 people I just put her together.as long as there is wet water like stuff and its soft,She rides thru with ease.
Fri Mar 10, 2017 8:04 pm |
flint87
Re: Speed!! MPH
1836 godevil duck skiff 23 gdlt with timing advance and partially gutted stock exhaust turning a slightly worn 9x6 GD prop Got 19 with 2 men going up river. 21 down river.
Just decided to start posting here bc I have now installed some homemade duals and a 34 MM round slide mikuni. Going to order a 9x7 BW prop and try again soon. Eventually will do heads and a cam on this motor.
Sun Mar 12, 2017 3:43 pm |
Glades Ranger
Joined: Mon Sep 19, 2011 6:32 pm Posts: 1490 Location: south Florida
Re: Speed!! MPH
Great speeds, Flint! Some day I will get a true flat hull and be optimum with my motor. 20 mph is just right.
_________________ Sailing in the sawgrass /1648 grizzly and Swomp 26.5 EFI
Mon Mar 13, 2017 8:03 am |
flint87
Re: Speed!! MPH
Mon Mar 13, 2017 9:49 am |
