It is currently Wed Apr 01, 2026 2:26 am
[ 6 posts ] |
Mattjw
 Kohler trouble
Has anyone experienced a hot start issue with a Kohler command 25. Mi e will fire right up cold then after running hard it will try to choke out at low idle. Once it is off it is hard to light back off until the motor has cooled down. Usually ends up flooding before I can get it to start. Maybe float stuck on carb?
| Mon Sep 26, 2016 10:25 am |
Will C
 Re: Kohler trouble
Could be time for a leak down test to see how the valves are sealing.
| Mon Sep 26, 2016 10:29 am |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
 Re: Kohler trouble
Might be an issue with the electronic fuel shutoff solenoid?
I took mine out and cut the needle off the fuel shutoff and then reinstalled the solenoid. I've been running it like this for years.
Let us know what you figure out, I am running an '02 25 hp Kohler and it's been a good one.
| Tue Sep 27, 2016 5:24 am |
Mattjw
 Re: Kohler trouble
I rebuilt the carb and everything seems to be working good knock on wood. Definitely was some gunk up in there
| Thu Oct 13, 2016 4:00 pm |
Will C
 Re: Kohler trouble
Good deal.
| Thu Oct 13, 2016 4:36 pm |
Mattjw
 Re: Kohler trouble
Thank you for the help fellas
| Thu Oct 13, 2016 5:29 pm |
[ 6 posts ] |
