It is currently Wed Apr 08, 2026 11:00 pm
Reply to topic  [ 2 posts ]
 What size prop
Post What size prop
Ok guys I am running a 14 ft john boat with a 22 hp predator engine with a 7x4 prop on a go devil frame. I am only running 8mph loaded and basically the same unloaded with just me in the boat with a 6 gallon tank and battery. What size prop do I need to be running. I see 16 ft boats on you tube same set up that are running in the upper teens to lower 20s. Any help would be appreciated thanks.
Sat Dec 17, 2016 7:23 pm
Post Re: What size prop
I've got a 23hp vanguard on a 1438 jon and I run a 9x5 and get the right rpms. You could probably run that. At peak rpms I'll see just over 17mph.
1438 Jon / 23hp MBLT
Tue Dec 20, 2016 10:30 am
cron
