It is currently Wed Apr 08, 2026 10:57 pm
Reply to topic  [ 9 posts ]
 wiring kill switch
Post wiring kill switch
Is there any " how toos" on how to wire in a kill switch on a 13hp? Thanks
Tue Aug 15, 2017 7:03 am
Post Re: wiring kill switch
tap into the engine "kill wire"
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Aug 15, 2017 8:06 am
Thanks for the reply. where might that be located? Also, my kill switch has 3 prongs on it if I remember right. Im guessin that that once I locate the "engine kill wire" its one in and one out but where does the 3rd prong go.
Tue Aug 15, 2017 10:40 am
Most of them have 4 prongs, but you only use 2 of them. Wire it up, try to crank it. If it doesn't crank move the connector to a different prong. Once it cranks, verify the switch will kill the engine. Quick lazy way I normally wire them up.
The kill wire is located on the side of the engine. The little switch that turns it off. Is it a Honda?
Tue Aug 15, 2017 3:07 pm
Tue Aug 15, 2017 4:09 pm
Sounds like a duromax, does it have the little dial kill switch on the side? If so, tap into that.
Tue Aug 15, 2017 5:15 pm
no, its a electric start / key
Tue Aug 15, 2017 7:45 pm
the Black wire with the red stripe is your kill wire going to key ignition. tap it and run to your "kill switch" or find it coming out from under your engine cover.
Wed Aug 16, 2017 7:52 am
10/4 Thanks! Ill look for it today after work. I could just go without it (like some do) but I understand the importance of it.
Wed Aug 16, 2017 1:51 pm
cron
