It is currently Fri Apr 19, 2024 8:16 pm
Reply to topic  [ 9 posts ]
 18hp duromax rat tail build
Post 18hp duromax rat tail build
Hey all,
New to the forum and started a new project, so I've been soaking up some info. My 6.5hp Thailand longtail has worked well pushing my 14x36, but its time for an upgrade. I recently got this farm engineered rat tail for $200, it was set up as a chain/sprocket with a 5/8" keyed prop. I'm cutting it down and threading it to fit a 3/4" threaded BPS 9x5 tiger prop and swapping out to a u-joint assembly. Also replaced the some bearings and seals. Finally its being married up to a 18hp Duromax. I'm open to any and all feedback or pointers as this is my first build.
Thanks for the add!
Fri Oct 11, 2019 10:50 pm
Post Re: 18hp duromax rat tail build
Little bit of an update. Whats with the lag time in posting on this forum?
Wed Oct 16, 2019 6:03 am
Looks like a cool little set up bro. If it gets you to the ducks, then it’s a success for sure bro!
Wed Oct 16, 2019 12:41 pm
Finally made a little progress. I cut the tappered 5/8 portion off the end of the shaft, then threaded it to 3/4 #10 to fit the BPS tiger 9x5. Still not sure how well the 18hp will turn that size prop on my 1436 flat bottom, but thats what the BPS website recommends.
Sun Oct 27, 2019 4:29 pm
New Member
OP, where did you find those bearing housings/couplers?
Sun Dec 29, 2019 9:19 am
Why is it so many of these interesting threads die such a quick death? ....usually just after three or four posts??
Sun Apr 05, 2020 8:07 pm
Because that thing probably ran like a turd and he scrapped it.
Wed Apr 08, 2020 1:34 pm
Pound For pound. Single cylinder clone engine duromax 18hp is king . Biggest big bore. and all gx390 hop ups fit. Im running 25 mph on a 1436 w/ modded 18hp mated to a cheap twister
Sat Feb 06, 2021 7:50 am
That’s fast as fuck for that little rig. Good stuff bro
Sat Feb 06, 2021 9:08 am
Users browsing this forum: No registered users and 258 guests
cron
