It is currently Sun Jun 09, 2024 5:46 am
Reply to topic  [ 10 posts ]
 gdlt BUSHING REMOVAL
Post gdlt BUSHING REMOVAL
i have gdlt frame i need to change the lower bushing i read the manual. it states to cut the the bushing in two locations. i am not sure where to cut the bushing. i think it is the new seal system i attached a couple of pics.
Sat Apr 10, 2010 3:21 pm
Post Re: gdlt BUSHING REMOVAL
heres a few more pics. i think this is the new seal system.
Sat Apr 10, 2010 3:23 pm
get u a sawzaw with a metal blade or a few blades cuz its going to eat them up and put in to were the shaft was coming out and cut it like a cross ( + ) its alot easier to get out in 4 pieces. then get u a flathead strew driver and tap each piece in word till they fall out. hope this helps man
Sun Apr 11, 2010 10:47 am
Profile YIM
That's interesting. You have the new style seal collar with the old style bushing. The new bushing has a helical cut groove inside and a slot in the edge for grease to circulate.
To pull bushings I weld a 7/8 tap to a 3/4 X 10 long nut. I screw a long threaded rod into the nut, slide a piece of pipe on the threaded rod and put a nut on the end of the rod. Screw the tap into the old bushing and use this as a slide hammer . It removes bushings quickly with no chance of damage from the saw.
Sun Apr 11, 2010 1:15 pm
i removed and changed the bushing with no problem i put it all back together started filling up the shaft with grease upper seal leaking. Any tips on changing the upper seal.
Mon Apr 12, 2010 7:41 pm
Tue Apr 13, 2010 11:58 am
reciprocating saw
Wed Apr 14, 2010 9:59 am
:roll: :roll:
ETD88 09/28/09-05/14/2010...
Wed Apr 14, 2010 10:08 am
-1436 flatbottom
Mon Apr 26, 2010 7:32 pm
Tue Apr 27, 2010 5:46 am
Profile YIM
Users browsing this forum: No registered users and 63 guests
