It is currently Sat Jul 19, 2025 6:33 pm
Reply to topic  [ 21 posts ]
 anyone with 3.31 gears?
Post anyone with 3.31 gears?
Just ordered a 2015 f350. The only one I found with what I wanted has the 3.31 gears. I have always went with the 3.55. I don't think there will be that much difference. The most I tow is 12,000 lbs. Plus this 6.7 has 40 more hp and 60 more pounds of torque than my 2012. Any opinions? Thanks
23 swomp/ 1542 tracker
Fri Mar 27, 2015 6:04 pm
Post Re: anyone with 3.31 gears?
That's a tall gear... You a flatlander? I ran an old Chevy with 307's a long time ago, rascal would stroll but was hell on u-joints! U shouldn't have any trouble unless you're running in the mountains I wouldn't think.
PRODRIVE 1860 CC
"Let the good times roll"
Fri Mar 27, 2015 6:18 pm
I know it's totally different but. My personal f_150 has 3:55 gears with the ecoboost engine. My work truck is the same with 3:15 gears. I couldn't find any difference pulling my airboat. I know it's not that heavy but it's like pulling a parachute.
Fri Mar 27, 2015 6:24 pm
It is all flat by me except once a year I take the boat to the Atlantic
I would say the ratios in the transmission will be geared to accommodate the higher ratio
''It's just 90 foot you're gonna die if you fall 20 foot so whats another 70 foot'' Jason Humble climbing school 12'
Sat Mar 28, 2015 9:33 am
I'm sure it all has to do with unloaded fuel economy set by the EPA. I know the 6.7L in a f250 with 3.55's really hauls the mail. The transmission ratios take some of that into account as well. Typically I seen the 350's have deeper ratios such as 3.73. You may want to look into it. Is it a DRW F-350?
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Tue Mar 31, 2015 7:35 am
Just picked it up yesterday. I think my calculating is correct with 3.31 gears and 18" rims that brings it up to about 3.45 ratio. I was worrying about nothing. The fukn thing flies
Tue Mar 31, 2015 2:58 pm
I have the 3:31 gears and have never wanted anything higher numerically. Mine has the 20" rims and I average 18 mpg. That is normal driving not babying it. The heaviest thing I pull is about 12,000 lbs and that is on flat ground. If you don't tow in the mountains you should be fine.
Tue Mar 31, 2015 7:06 pm
Rim size has no effect, tire size does and a 3.31 gear set still is a 3.31 gear set.
Wed Apr 01, 2015 7:14 am
Bayou Surface Drive
337-351-0362
Wed Apr 01, 2015 9:18 am
Yea. Sorry I didn't specify. The larger rim has a bigger tire. Sits 3/4".higher
Wed Apr 01, 2015 1:11 pm
You math is going wrong way. if you go from a say a 31" tire with 3:73 to a 35" tire you are going to want around a 4:10 to get you back to "stock"
Wed Apr 01, 2015 2:53 pm
Stop making me have buyer's remorse you assholes. Let my math be wrong and tell me that I am right
Wed Apr 01, 2015 3:50 pm
:lol: :lol: it will tote the mail regardless and gear sets are cheap if you want replace them as long as you do work yourself :lol:
Wed Apr 01, 2015 6:16 pm
Bayou Surface Drive
337-351-0362
Thu Apr 02, 2015 7:03 am
Thu Apr 02, 2015 10:13 am
Y'all are just splitting hairs now lol
35 GTR - 1754 Extreme
Thu Apr 02, 2015 12:25 pm
If the truck is rated for 12,000# pull 12,000# and don't worry about it.
I pull approximately 10,000# with 3:55 gears and a gas engine. Although I don't pull it that far or that often. Never had a problem. I just pull it in a lower gear to be safe.
Thu Apr 02, 2015 1:13 pm
Bayou Surface Drive
337-351-0362
Thu Apr 02, 2015 3:16 pm
Yep mine looked like someone took buckshot to mine
Thu Apr 02, 2015 3:36 pm
34" tires ( factory), 20" rims , 3:31 gears. Truck is rated for 15,000 lbs so the the final drive in the new six speed must be pretty low.(higher numerically).truck is fast for a big truck but I did get beat by a 6.2 raptor the other day.
Thu Apr 02, 2015 5:47 pm
Users browsing this forum: No registered users and 135 guests
