It is currently Wed Jul 16, 2025 11:09 pm
Reply to topic  [ 22 posts ]
 diesel programmer
Post diesel programmer
Whats yall opinions/experience with programmers?
All stock 6.7 cummins.
was thinking egr delete, exhaust,and either h&s or efi live tuner.
I dont know too much about any of this...any experts?
Wed Apr 29, 2015 4:36 am
Post Re: diesel programmer
I have an 07 with the 6.7 and I put the h&s on mine with egr delete and 4"exhaust. It's a single cab with a custom welding bed and a lincoln 200 on the back with all my tools and what not. Im getting 16-17mp. Was about 5 less before programmer. I would suggest going ahead and putting an air dog system on it as well.
Wed Apr 29, 2015 5:37 am
My 3500 6.7 has been de-epa'd with a 5" straight back. Does 25 mpg cruising 70. The guy that did it told me to keep the tuner on "race" mode and just keep my foot out of it.
It voids the warranty when you do this though.
Wed Apr 29, 2015 5:44 am
MBRP or Flo-pro exhaust with EFI live by PPEI Kory Willis. You wont be disappointed :shock:
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed Apr 29, 2015 7:39 am
PPEI (Kory Willis) is the go to guy. When I was lead tech at Hurricane Offroad in Lake Charles we got 90% of tuners from Kory. He has tons in stock H&S or his personal line as well.
I've got tons of experience with these rigs. Honestly all you need to do is BLOCK the EGR, no need to remove it unless you have to have that. Tune the truck Unplug the EGR motor, the EGR servo on the EGR cooler, and the plug at the EGR throttle plate, then replace the exhaust. To remove the exhaust you have to pull the trans cross member to remove the stock head pipe that bolts to the factory downpipe. Also unplug any and all sensors in the exhaust stream and tie them out of the way. Be careful unplugging the DEF injector in the exhaust they are typically a plastic coupling. Install new exhaust and have fun.
Also if you go with a 5" it is a VERY tight fit between the trans cooler lines and the stock frame rail/ trans cross member. Its a chore to keep them from rattling. Also all the talk about 25 MPG is a lie... The computer may show that much mileage but it is only calibrated to read factory fuel maps that's why you see crazy high numbers. 17-19 is believable depending on the setup. Hand calc numbers are the real numbers with a correctly calibrated speedometer.
Wed Apr 29, 2015 7:53 am
Get kory Willis you will pay about 600 for joeys tune and you will pay about 2200 for a h&s and will have to keep updating it
18x48 extreme with 37 gtr
past boats
07 gtr on 16x54 alweld
Wed Apr 29, 2015 9:18 am
So...kory willis sounds like the man.
egr, since its to do with the exhaust, im gonna guess its exhaust gas recirculator?
Wtf is dpf delete? Is that the shit u gotta pour in? Mine is 2010, u dont have to put that additive,
so i guess i dont need dpf deletes?
told yall i didnt know too much about this.
Wed Apr 29, 2015 12:15 pm
That's DEF fluid
You still have the DPF filter in your exhaust 2007.5 ^^ You can tune with emissions in place or without. Far better gains without but not legal.
Wed Apr 29, 2015 1:04 pm
Wed Apr 29, 2015 1:10 pm
H&S black maxx with 5" turbo back exhaust. Do the get delete
Wed Apr 29, 2015 2:41 pm
H&S not doing business right now.
18'x54"CC Hanko/ 36PD
Wed Apr 29, 2015 5:34 pm
Wed Apr 29, 2015 6:00 pm
Sooo.....def is the fluid u add, which i dont have.
egr and dpf are in exhaust? Dpf is a filter? If i change exhaust, i will need these deleted? Unplugged?
blocked off? Or what?
it would be soo much easier if i could just bring it to jamieb up da road!
Thu Apr 30, 2015 1:14 am
Def= urea Egr is on motor dfp is in exhaust can diesel particulate filter if you delete you will need a tuner to void the engine code !!!!
Thu Apr 30, 2015 2:49 am
Thu Apr 30, 2015 5:47 am
Good thing is that def filter is worth some big bucks. The dodge one will sell for 600 bucks, gm goes for 350. Can pay for exhaust with that. As for tunes efi live is where its at, you get a tune for your truck, not everything under the sun.
Thu Apr 30, 2015 9:23 am
Not sure why but that efi live was kinda the way i was leaning.
With efi live, i still need someone like willis to tune it... correct?
Who buys the def filter thats in the exhaust?
and finally...is efi live dpf and egr delete capable?
Dammm this is confusing shit!
I guess its like the mudmotor...exhaust first right?
Thu Apr 30, 2015 12:04 pm
Thu Apr 30, 2015 12:45 pm
Yes, they can turn off egr and dpf with efi live. I had mine tuned by Rob coddins aka Idaho rob at adrenaline truck performance. He has been tuning Dmax for over a decade and was one of the first to start tuning the Cummings via efi live. As for exhaust buyer I can look up his number if you need it.
Thu Apr 30, 2015 1:15 pm
Dmax, why are they worth so much? Is there cryptonite in there or something?
do u know?
Fri May 01, 2015 1:06 am
Fri May 01, 2015 1:39 am
Fri May 01, 2015 4:28 am
Users browsing this forum: No registered users and 64 guests
