It is currently Tue Jul 08, 2025 10:28 am
Reply to topic  [ 14 posts ]
 Prop replacement problem
Post Prop replacement problem
Knocked the f*** out of my prop an now need to replace it. Didn't bend the shaft, just one blade it is a screw on prop and the shaft has a little rust on the threads. WD40 hasn't broke it free yet. Don't want to hit it too hard and chance bending the shaft. Any help?
Mon Feb 01, 2016 9:13 pm
Post Re: Prop replacement problem
What kind of mud motor we talking about here . Sd. , longtail. , make ?? A little more info .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Mon Feb 01, 2016 9:27 pm
04 25hp Mud Buddy HD. Bought it used 3 years ago.
Mon Feb 01, 2016 9:56 pm
Try PB blaster, WD40 won't break free that kind of stuff. Do a search, there are some other products people have used, I always use PB blaster because you can find it at autozone, Walmart etc.
Spray it down liberally, repeat for a couple days to let the science happen, then give it hell.
Tue Feb 02, 2016 5:00 am
Have you tried searching "stuck prop" yet? There are probably two dozen threads that will pop up... Take a look.
-Custom pool noodle
-stage 4 water wings
Tue Feb 02, 2016 5:25 am
You're gonna need a sledge hammer, plasma cutter, and vice grips.
Tue Feb 02, 2016 6:25 am
A little heat helps - so does a prop removal tool....
Eat - Sleep - Hunt ! ! !
Tue Feb 02, 2016 8:07 am
Not worth fucking with!!About like a godevil,Throw that pile of shit in dumpster and go see Kyle at GatorTail!!thank me later
Tue Feb 02, 2016 11:17 am
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Feb 02, 2016 11:21 am
And the gt fanboy runs off another customer....
Tue Feb 02, 2016 11:41 am
1854 Prodigy DPE Level 3 HDR
Tue Feb 02, 2016 12:38 pm
Make yourself a prop removal tool, using a 2" wide piece of 1/4" thick flat stock about 4' long. Drill a 7/8" hole in it about 3" back from one end. So it fits over threaded part of shaft. Put a small pipe wrench on the bushing behind the prop with a cheater pipe on it, that will touch the ground and power it off using leverage, most come off pretty easily after soaking with panther piss Liquid wrench.
Tue Feb 02, 2016 12:51 pm
Once you get it off see if you can get a hex shaft for it instead of the threaded one. That's the best thing anyone could have ever done for one of these motors...going from a go devil with threads to the gatortail with the hex shaft was the shiz nit
Tue Feb 02, 2016 1:46 pm
PB Blaster....plenty of it and overnight soak.
Tue Feb 02, 2016 1:47 pm
Users browsing this forum: No registered users and 74 guests
