It is currently Sun Sep 07, 2025 11:27 pm
Reply to topic  [ 10 posts ]
 LED light bar.....
Post LED light bar.....
I want to buy a led light bar that I can run off my 2000 watt Honda generator.
I was all set to order a light bar and wiring harness off Amazon and realized I need a 110 light bar not a 12 volt.
I would like a 20 inch or longer that is part flood part spot.
Any suggestions?
18x48 GDSD boat
Sun Oct 23, 2016 7:58 pm
Post Re: LED light bar.....
Do those little Hondas not have a 12v outlet? My dad has one and I believe I remember it having one for some reason.
Or scoop up one of these...
iSaddle 110V AC to 12V 10A DC Power Converter https://www.amazon.com/dp/B00QK79PWQ/re ... dyb7T960BG
-Custom pool noodle
-stage 4 water wings
Sun Oct 23, 2016 8:11 pm
Selongtail I will take a look at the honda. I bought it recently as I have been using a 12v to 110 converter in my boat to run my large aeration system. I fish a lot out of town and got the Honda to run my 110 tools if needed along with making coffee in the boat. I need a good night light for working on the river after it gets dark.
18x48 GDSD boat
Mon Oct 24, 2016 4:42 am
make a pot of coffee and look around on amazon for the light u want. lol
I keep a 24'' spot/flood led lightbar with a long cord to use as a worklight. it is easy on the battery. [12v] [$30]
I also keep a antigravity battery in my boats in case I run out of battery.
the 12v side of your Honda should run a led lightbar no problem.
Mon Oct 24, 2016 6:28 am
The generator said it has a 12v 8amp charging plug. It's labeled 'for charging battery only'.
How much of a led light could I run off that?
18x48 GDSD boat
Wed Oct 26, 2016 6:27 pm
one that uses less than 8 amps?
https://www.amazon.com/Nilight-Driving- ... omotive_63
I use this one, for 29$ u can't go wrong. do not know how many amps it takes, but it ain't much.
I run one on the boat and on my gas golf cart, no issues.
for the 110 generator.....
https://www.amazon.com/Equivalent-Water ... 92M9E7YZZ2
for a worklight in your boat, I use these 10watt led lights in my boatshed and at the camp to b easy on the generator. they give off good light that won't blind everybody. 2 or 3 of these on a pole would light up a lot of boat/gillnet and not even strain that Honda. I have the 100 watt light and the 10 watt, I like the 10 watt better, works like a drop light. the big 100 watt floodlight shines up about half my front yard. lol
didn't look at the lights in the link, but get the ones with the plug on them already, or just get a extension cord and cut off one end and plug it to generator.
https://www.amazon.com/gp/product/B006S ... CXNQHG8XZ1
Wed Oct 26, 2016 6:35 pm
or u could go straight pimp with these.....change colors with your mood........
https://www.amazon.com/dp/B005KYOE2Q/re ... B006STWHE4
Thu Oct 27, 2016 4:26 pm
Joel the one you have is 10.5 amps at 12volts.
If the honda has a 8amp 12volt plug you can get like a 12" 72watt light bar and plug it in there. 96 watts is 8amps at 12v
I gave up mud motors
Fri Oct 28, 2016 11:13 am
Thanks for the info Joe Pete
18x48 GDSD boat
Fri Oct 28, 2016 5:32 pm
sounds like t-bubba had the right light!!!! they got them all day on amazon.
good luck!!
Fri Oct 28, 2016 7:24 pm
